#113 | |
Only users lose drugs.
Drives: All the time
A very valid and unique situation, especially when you consider that the moment you have coil bind, you're effectively suspensionless. At that point (and ONLY at that point onward) the vehicle's chassis becomes it's suspension as well. But until that happens, any wheel movement needs to happen through the suspension, as that's the whole reason it's there, and a stiffer chassis will make it work more effectively and predictably. Motorcycle frame design started allowing more lateral flex about 15 years ago to compensate for the extreme lean angles that race bikes were increasingly capable of producing. However, this is due to the uniqueness of motorcycles in that their suspension is effectively turned on it's side at these lean angles, and therefore unable to cope with vertical movement in relationship to the road surface. Certainly not applicable with cars. If you're trying to tune this car's performance by adding additional chassis flex, you've already screwed up your suspension selection. Last edited by venturaII; 11-17-2016 at 09:35 AM. |
#114 |
Drives: FR-S Whiteout
I'd put this product in the same category as the TRD door stabilizers. I'm sure it does something positive but only difference I notice was a lighter wallet and having to close the doors harder than without. Looks cool though. lol
Intent > Content
cowardice is the mother of cruelty. |
#115 |
Drives: Strangely.
Lol I got those door latches too. I think it maybe made the car handle better, and totally ruined the ride quality.
My FR-S has a build thread!
(It's mostly full of Nissans) |
#116 |
Because compromise ®
Drives: Red Herring
When discussing butt dyno many people get traction and friction mixed up. This is why lube is suggested and according to the research I've seen is highly recommended.
#117 | |
To be fair, having driven my car with and without a front strut bar. I can say there there is a difference felt driving at the limit. I'm sure these strut bar/damper things will have some effect in the feel just as a solid bar has an effect. Probably somewhere between not running any bars vs just the stock bars.
Intent > Content
#118 |
Dismember
Drives: 2013 Red Scion FR-S
If you guys want to buy me these things, I'll put them on my car and AB with both the bars on, bars off, and stock bars.
#119 | |
Proud of BOXER
Drives: Subaru Boxer
For it to be accurate you will have to have someone else installing/uninstalling without telling you, so that you aren't biased when you know they are installed!
#120 |
Drives: Red Herring
I think a better test would be to put one on just one side and keep the stock bar on the other side and see if you drive around in circles.
#121 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I'm gonna get this. Need more TRD in my build.
#122 |
Dismember
But if I pay somebody to do that, they might just install them backwards.
#123 |
Looking at that list you got in your sig. I think this type of product is a perfect fit for you. lol Let us know what your impressions are when you install them.
Intent > Content
| Prothane Motion Control Looking for Test Vehicle | itsibarra | Southern California | 2 | 05-22-2015 01:13 PM |
| Motion Control Suspension coilovers | xwd | Tracking / Autocross / HPDE / Drifting | 27 | 02-21-2015 11:24 PM |
| is there a shorter endlink out there? mcs motion control damper | toby714 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 10-19-2014 08:28 PM |
| motion control suspension(mcs) spring length | toby714 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-21-2014 12:42 PM |
| Motion Control Suspension | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-30-2014 11:55 PM |
