Old 11-28-2016, 02:53 PM   #141
CSG Mike
CSG Mike's Avatar
I meant for heat
In that case, in the box the turbo came in, not in the car.
Ptuning has the best heat management, period.
Old 11-28-2016, 03:02 PM   #142
Ashikabi
Ashikabi's Avatar
How much sacrifice is all that charge piping? Does the intake being in the engine bay make much difference for a turbo application?
Old 11-28-2016, 06:36 PM   #143
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Can =/= should.
Whether you can actually safely run a HBP on pump depends on your supporting mods, and tune. Because there are so many permutations and tuner choices, the safer recommendation is to give a blanket "No", and let the end user talk to their choice of tuner and decide if they want to go against the recommendation.
The car tuned by Vit, uses an Ace A/350 ceramic coated header.
The CSG BRZ (also with a ceramic coated Ace header) is capable of redlining on a C30 with HBP on ACN91, but isn't typically run that way on track. Even with a 91 octane tune, race gas is utilized at the track.
That's understandable & I figured as much that was going to be the case.
I'll hit CSG up when I'm closer to being ready to purchase a JRSC kit
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 11-29-2016, 07:52 AM   #144
Calum
That Guy
Drives: 2013 asphalt FRS MT
You should see what happens when a good header is paired up with the JRSC
You've been saying that for a while. Is there any chance you could show us? I'd love to see JRSC vs JRSC + ACE, or JRSC + ACE vs Edelbrock + ACE. I'm sure a lot of others would like to see this aswell.
Old 11-29-2016, 07:58 AM   #145
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Pretty much impossible to find that on regular fuel. ACE have no such data. And it looks like Delicious have nothing they can publicly show.
Michele Abbate (Edelbrock+ACE) and Oscar Jackson (JRSC+ACE) will keep that secret for obvious reasons.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 11-29-2016, 08:01 AM   #146
Calum
That Guy
BOOOO!!!
Old 11-29-2016, 10:58 AM   #147
gtengr
Drives: 2017 BRZ
I'm also very interested in those results. Superchargers tend to love big headers.
gtengr is offline   Reply With Quote
Old 11-29-2016, 11:20 AM   #148
bfrank1972
Drives: 2013 FR-S Argento
Same here, though I ran across this thread a while back:
http://www.ft86club.com/forums/showthread.php?t=47101
According to Drift Office, a tuned Vortech kit with an HKS EL header (decent header) vs stock header, wasn't as much of a difference as you'd think.
From what I've seen in general, most FI kits get rid of the torque dip. Job #1 for an aftermarket header on a NA car is to do just that. Bang for buck, might be more cost effective to invest in a HBP and a blow off valve than a $1400 header
Edit: would also be interested to see how a gutted stock header would perform
Old 11-29-2016, 11:41 AM   #149
MaximeT
MaximeT's Avatar
It looks like Delicious calibration is very often massively superior to others when a ACE header is involved.
Old 11-29-2016, 12:13 PM   #150
Icecreamtruk
Drives: Track preped NA FRS
They have so much more time on the dyno behind it. I bet all of the runs that CSG did on the dyno testing and improving on the ACE header is on their hands (as they seem to work together). So it makes sense that their tunes are vastly superior when it comes to ACE headers.
Icecreamtruk is offline   Reply With Quote
Old 11-29-2016, 12:18 PM   #151
MaximeT
MaximeT's Avatar
Yes exactly.
ACE, Delicious and CSG worked hand in hand.
Old 11-29-2016, 01:39 PM   #152
Calum
That Guy
This is why I'd much prefer an canned tune, that has as much time behind it as DT's tunes do, than a tune done in four hours on a dyno. It's likely to be cheaper, and better for 99% of the tune. You might leave a couple of horsepower on the table, in that one particular atmospheric condition, but that's likely to be it.
Old 11-29-2016, 02:01 PM   #153
Ashikabi
Ashikabi's Avatar
How's the rumble on the ace headers?
Old 11-29-2016, 02:05 PM   #154
MaximeT
MaximeT's Avatar
Yes, unless you spend 7k on custom tuning like CSG, there's no point not using Delicious.
ACE own racecar use a Delicious tune.
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 02:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 10:26 AM
Jackson Racing Kit AT6 CladMonitor Forced Induction 26 06-27-2014 11:27 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
