Drives: 2013 Argento FR-S
Rocker Arm Failure
I currently at 42K miles have a rocker arm that was pushed through the valve cover. Toyota is attempting to deny my P/T warranty for this for "over rev" because freeze frame data shows at some point i was at 7300 RPM at 35 mph.
Regardless of that i wanted to see if anyone else has had this failure. Who has had a rocker arm failure ? What mods did you have ? Did Toyota/Subaru cover under warranty ? |
#2 |
Drives: Track preped NA FRS
7300RPM, how is that over rev? Thats below the cutoff, so normal rev. Dont let them deny it for that, it is not true at all, there are many others (including myself) who get to 7300 on every gear, lap after lap after lap
#3 |
Im trying to fight them on it but they are stone walling. I will be contacting an attorney and i bought a beater vehicle to allow me time to fight.
#4 | |
http://www.ft86club.com/forums/showthread.php?p=2646846 http://www.ft86club.com/forums/showthread.php?p=2399777 http://www.ft86club.com/forums/showthread.php?t=19672 http://www.ft86club.com/forums/showthread.php?p=1184772
#5 |
Drives: 2013 Pearl White 6MT
Guess im still trying to figure out how you can be in 7300 at 35
What gear? Were you about to shift out?
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#6 |
1st gear. If you are launching from a dead spot for maximum acceleration, you would want to shift at the redline (7400) on every gear, that includes first gear.
#7 |
#8 | |
#9 | |
I have dealt with the dealer and Toyota corporate. They both advised me the District Toyota Parts and Service manager made the final denial to deny it and both refused to give me his contact info. I tracked him down and left him a message. I do have a copy of the freeze frame, it was pulled when a code for a misfire popped up. The problem with that, is the freeze frame data has evidence that it was not pulled at the time of failure. The ambient temp reading is different from what it was the day of failure. Also the coolant/oil temps were also different than what it wouldve been as when the freeze frame was pulled coolant/oil was around 120 degrees, when i had been driving for 45 minutes when this failure occurred so everything would be over 200+. Also i had been driving that morning for a while, but the freeze frame data for that rev was 66 seconds after start up of the vehicle. So Toyota cannot prove that the freeze fram they are using to deny my claim occurred when the failure occurred but i have plenty of evidence to prove it wasnt from the same time and cannot be used. Also the fact that 7300 rpms is under the factory set rev limiter is one of my points as well. |
#10 | |
#11 |
Drives: 14 Ultramarine FR-S
Indeed it does...
All those threads listed have been on MY13, I wonder if there are any MY14+ that have recorded this issue. Guess its good I haven't seen any pop up yet >_>
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#12 |
I have seen one 14 and one 15 that had the issue. One (don't remember which or what thread) was FI and the other was a massive over rev. The guy with the over rev was positive that he didn't cause it but said he had a miss shift from 5th to second so there is little doubt that it was the direct cause. Actually if I remember right that thread may have got deleted because the guy was going to take them to court. Don't remember any follow up if there was one.
#13 |
They are completely ignoring my requests to speak to the person that denied it.
Ive reported Toyota to the BBB and the VA AG Bearau of consumer protection. |
#14 |
Edit.
| Rocker Noise normal for the BRZ?? | BRZnut | Issues | Warranty | Recalls / TSB | 8 | 12-21-2015 07:53 PM |
| Roller Rocker price | sam69 | Engine, Exhaust, Transmission | 9 | 12-19-2015 12:00 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| Rusty Rocker | Nassty | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 04-01-2014 08:47 PM |
| Right quarter and rocker - Ottawa | Mgb_bj70 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-01-2014 04:23 PM |
