Old 12-12-2016, 03:26 PM   #57
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
OP has the most fitting name for this particular event.
LOL.
Good luck with your claim. I sincerely hope you win. I hate dealerships and warranties. I hate the way they snake out of doing the work, I hate their brainless techs, The management sucks.
I've said it before, and I'll say it again. I voided my warranty and bought my FRS. In that order.
Driving that car away was the least stressful thing I have ever done.
One way to avoid the headache.
Don't have the car anymore, but the Honda and the other Toyota are both more than a decade out of warranty, and it's so liberating to never have to see those smarmy little over-dressed f*cks in those too-expensive buildings.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 12-12-2016, 03:49 PM   #58
Worstenemy453
Drives: 2013 Argento FR-S
It can bounce off of the factory rev limit all day as long as the oil doesn't overheat. The rev limit argument is total BS.
Based on the freeze frame they are using to say over rev the oil was definitely not over heated. So that is out also
Sent from my SM-G935V using Tapatalk
Worstenemy453 is offline   Reply With Quote
Old 12-16-2016, 04:00 PM   #59
Lonewolf
Lonewolf's Avatar
Drives: Moped
I know it's only been a few days since the last post, but anything new?
Old 12-16-2016, 05:10 PM   #60
Worstenemy453
Toyota blew off the BBB complaint. Haven't heard from FTC or NHTSA and a overnighted letter was sent requesting a written denial letter and if one wasn't received in a reasonable amount of time it would be viewed as refusal of the request. I plan on doing a small claims court case for $5k soon. I honestly think they'll settle at that point but I think my case is strong enough to argue if they want to send someone.
Old 12-16-2016, 07:14 PM   #61
Lonewolf
Lonewolf's Avatar
Drives: Moped
Document every encounter and communication with Toyota reps/dealer and gather as much written material as possible to aid in your claim. I'm pulling that you get this resolved in your favor sooner rather than later.
***Have you looked into the VA Consumer Protection Act to see if there is any provision covering warranties/guarantees?
Old 12-16-2016, 07:17 PM   #62
Lonewolf
Lonewolf's Avatar
Drives: Moped
Old 12-16-2016, 07:22 PM   #63
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Hope you get this worked out in your favour.
In Canada we're on the metric system, so redline is 20,000rpm.
When we get pulled over for doing 90, it's because we're going too slow.
Seriously though, good luck.
geezerbrzeezer is offline   Reply With Quote
Old 01-17-2018, 04:11 AM   #64
Turbo86
Drives: '13 Whiteout FR-S
Curious how this turned out
Turbo86 is offline   Reply With Quote
Old 01-19-2018, 08:05 AM   #65
BRZnut
Drives: BRZ DGM Limited
ya, what ever happened???
Old 10-12-2019, 09:50 AM   #66
_keepkushin_
Drives: 2013 subaru brz limited
I currently at 42K miles have a rocker arm that was pushed through the valve cover. Toyota is attempting to deny my P/T warranty for this for "over rev" because freeze frame data shows at some point i was at 7300 RPM at 35 mph.
Regardless of that i wanted to see if anyone else has had this failure.
Who has had a rocker arm failure ?
What mods did you have ?
Did Toyota/Subaru cover under warranty ?
so i think i am currently going to find this failure when i have time to work on the motor and see. but i am currently at 85k and i was around 5th or 6th gear when my egnine engaged in what i see it as a soft shutdown. from what ive been told possibly an exshaust roller rocker that got pushed out due to loss of oil pressure which also i was told the oil pressure keeps it in place as the lobes rotate.
_keepkushin_ is offline   Reply With Quote
Rocker Noise normal for the BRZ?? BRZnut Issues | Warranty | Recalls / TSB 8 12-21-2015 07:53 PM
Roller Rocker price sam69 Engine, Exhaust, Transmission 9 12-19-2015 12:00 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 08:47 PM
Right quarter and rocker - Ottawa Mgb_bj70 Exterior Parts (Aero, Lighting, Etc.) 0 01-01-2014 04:23 PM
