#7701 |
Drives: 2013 Scion FRS
You guys are getting off topic...
ScreamingElectron - SnakeShit |
#7702 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Phil is always here and he can direct when there is a more critical issue (i.e. car not starting) and we attend to it as fast as we can. There are also internet complications like email not getting through, or a followup flag getting lost between the 3 different computers we use to keep workflow going. We emphasize that people need to CALL when you don't get a response back through email after a while. Also, one BIG thing is that we have no way to assess your hardware or installation. But for some reason the tune is always the first thing to get blamed. If someone provides incorrect hardware information, has leaks in the plumbing, kit has specs that change from the last one we did, or has some other issue...we have no control over that. And if we provide a tune within 48 hours (our job is tuning, not remote troubleshooting) that does not mean we can address everyone's issues in the same timeframe. We are not entirely without fault because we do miss emails here and there, but we have historically provided advice and hardware support at no charge. However this should not be an expectation. If a customer cannot do their own install--then it needs to go to a shop and then they can get tuned there if they'd like. Or they can have the shop work with us. But it is unrealistic to always get a response about issues not related to our products or services. Forums and FB groups are great for those resources. Another point we want to stress is most people save up for a while to get a FI kit, then wait for it to get to them, but then they expect the tune immediately. BUY THE TUNE FIRST! This allows us to schedule workflow and get you the tune ahead of time, then we know how many revisions we may have to do at a given time. ...now back on topic
#7703 | |
Drives: 13 DGM BRZ 6MT
I'm significantly less worried about tuning than I am why my car doesn't run however. I'll update here once I know. |
#7704 |
Maybe you could log an attempted start? Not sure if it's possible, but it'd probably give you a hint.
#7705 | |
Drives: 2013 Subaru BRZ Limited (Black)
You're pretty sure that all wiring is plugged back in, and that you've got the bolts all secured on everything (including the ECU mount)? Just thinking outside the box here... My initial thought would be that it may take a while to get cold start going on E85. |
#7706 | |
Unfortunately it's been 60 - 80 F here, so temp can't be the issue. I had the car towed to a shop, which refused to work on it due to the SC, then had it towed to a specialty shop which has been looking at it since. Still no word on what the issue is. Will update once it's confirmed. |
#7707 | |
#7708 |
Fuel air electricity.
Gotta be something upstream of your plugs.
#7709 |
Drives: SC BRZ
Copy/pasted from fb. Sry.
Ok. So some weird shit has been going on as of late. my SC maf bolt broke off a while ago so it's just plugged in and not too secure. I also have a boost tap on the maf that is capped off as my gauge took a shit. Car has always had the variable idle issue, and snapped the bolt holding a speed sensor on when putting my hub back together. Took to dealer to get rekeyed and now it's idling at 600 constantly and is in safe/limp mode. Usually I could reset the CEL and it would rev past 4K, but now to no avail. So throwing P0500 and U0073. Neither of which will clear completely and will come back. Car also will die randomly occasionally. Before I took it in I had a steering angle sensor code that turned off trac, airbags, and ABS after installing my wheel- but that's not showing now. Any ideas what I can do to get her running right? Mods: Sprintex SC, Perrin intake, keys racing wheel, coils, catback, etc. PFA |
#7711 |
Fuck the tune. Work on priority problems first, starting with ignition so you don't blow your motor. Then move down to things that will void your safety.
The tune can come last, you won't break your car in limp.
#7712 | ||
...Just add nauseum
Drives: 2003 (AP1) S2000
![]() ...EDIT: little too sarcastic... Little too mean... That is a dangerously incorrect statement. Quote:
P0500: Vehicle speed sensor. What did you do with the ABS sensor after you broke the bolt? U0073: CAN BUS off. This usually comes up when plugging in or unplugging an OBDII device while the car is running. ... I have a feeling that is going to turn into a fairly long troubleshooting process.
There are many ways to displace.
-Spartarus Last edited by Spartarus; 01-03-2017 at 01:09 PM. |
#7713 | |
![]() He's just a long way from dealing with the tune. Also you're right about it being dangerously incorrect. Just assuming he doesn't go balls to the wall on the throttle with a botched car.
#7714 | |
What does, taking it to the dealer to get rekeyed, have anything to do with your issues? I assume for rekey you meant to get new key fobs? I would look at your clearly fudged up map plate or your abs sensor and tone ring. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
