Installed ACT SB7-HDSS
I recently installed the ACT SB7-HDSS due to my OEM clutch slipping at higher gears. The issue with the new clutch is, I'm getting a stutter/issue when taking off from a dead stop. I have to rev it up from 850RPM to about 1200 for the clutch to engage/grab. But when it does, it feels like the car wants to stutter/buck/feel like it's dragging. It's making take off a bit challenging to be smooth
Is it that the idle RPM is low? Once I get going, it shifts perfectly fine. But taking off from dead stop is the issue. I'm running JRSC and e85. I have put 600 miles (city driving) on it and figured the issue would go away after breaking it in. Last edited by VABeachBRZ; 01-24-2017 at 09:52 PM. |
#2 |
driving smoother faster
Drives: Sold
Usually takes 2-3k miles to break in clutch. I have the same model and it has similar behavior, more so when warmed up and only noticeable when moving from stop. Add gas and don't ride the clutch. My car is rarely driven on street, primarily tracked, so it doesn't bother me.
#3 | |
After I'm in 2nd, it shifts smoothly. But the hesitation/strange feeling I'm getting is only when accelerating from a dead stop. Hopefully it's nothing major. I don't want to drop the trans trans then REPUMP oil in both the diff and trans lol |
#4 | |
Drives: Subaru BRZ / Toyota 86 Experts
#5 |
#6 |
Drives: 2017 Subaru BRZ
Was the flywheel re-surfaced? This could cause the "stutter/buck/feel".
#7 |
#8 |
The combination of boost, lighter flywheel, and drive by wire always has a small lag at first startup generally from stop in 1st gear. Sometimes a similar feeling is experienced during downshift rev-matching. The FA20 is not the most responsive system as well. Try slowing down all your actions and make them a bit more exaggerated in the beginning so you can feel out your car. Our CSG BRZ has the SB8-XTSS Prolite XTSS clutch kit on a high boost C30 setup. We can drive it in heavy traffic with minimal slip and chugging when most have issues even engaging that clutch without stalling. It's all in your actions and practice.
#9 |
Drives: 2015 Turbo FR-S
I have this clutch - it's easier to manage once broken in, but definitely doesnt feel like stock. Like the poster above said, practice and make your movements very deliberate. You'll get used to it.
#10 |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
I am about install this exact clutch along with an EBSC. Is this just normal adjustments that come with a new clutch, or is the stutter quite exaggerated.
CSGMike didnt mention much to me on this when we discussed this clutch, and i imagine he would have made note of it to me if it was going to be, a more than reasonable change. Just asking for my own expectations. I have ran a clutchmaster 400X on a boosted BRZ. I have ran a exedy Twin disc setup on a highly modified Evo X and driven a few other similar setups. Since the SB7-HDSS is not a drastic(track) clutch, I assume the issues the OP is having would come across as normal to someone with previous clutch upgrades. But let me know your thoughts.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#11 | |
Nonetheless, once I'm in 2nd, it's smooth as can be. I guess changing the position or engagement of the clutch threw me off. I have a long drive this weekend coming up. So maybe after a few hundred miles more, it will be better! |
#12 | |
#13 |
CAR-AHOLIC
OP - understand for sure. Its hard to gauge someones point of reference.
CSGdavid - I have complete faith in you all. Everytime i go against Mike's advice i realized i made a mistake. But with no car yet to install my parts, i have nothing better to do than ask hypothetical questions. Thanks.
#14 | |
Nice S2000 pic. Makes me want to drive mine again too, but with RC1s and 3" of standing water in heavy rain, I'll hold off a bit. |
| ACT HD clutch. SB7-HDSS slightly used SOLD SOLD SOLD | xkalelx | Transmission and Driveline | 2 | 04-10-2016 12:22 AM |
| Scion installed vs dealer installed fog lights | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 02-16-2014 01:55 PM |
| Tint, lights and backup cam installed, and camber kit installed in Gainesville area? | husker741 | Southeast | 2 | 08-16-2013 04:59 PM |
| Innovative SC Installed!!! Pics and dyno installed. | uspspro | Forced Induction | 15 | 04-02-2013 01:09 AM |
