Old 12-07-2016, 04:12 AM   #3053
DeaconRoc
Drives: GT86
Originally Posted by Adam_L View Post
So a good example of this would be Bilstein B14 coilovers?
In the post you quoted RCE are talking about Motorsport dampers like Bilstein club sports, motons, jrz, etc rather than sports dampers like the b14's. The same principles would apply but from what I've seen most of the sports dampers have more of a focus on high speed damping for better street civility.
DeaconRoc is offline   Reply With Quote
Old 12-07-2016, 08:14 PM   #3054
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Does anyone know if we can run Raceseng CasCam plates without using their spring perch?
Bach415 is offline   Reply With Quote
Old 12-07-2016, 08:28 PM   #3055
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes, but you'll have to come up with an alternate spring perch of nearly identical design, you won't be able to re-use the OE spring perch, might be able to make it work with a little adapter bushing thingy, but imo you wouldn't want to as you'd raise the ride height by >1/4"
Are you trying to save a few bucks or thinking of a quirky setup?
ineedyourdiddly
Old 12-07-2016, 08:58 PM   #3056
Bach415
Bach415's Avatar
Just trying to save a few bucks and that I noticed that they sell it without the spring perch thats why I was wondering about it as I currently am using kw spring perch for my setup.
Old 02-06-2017, 01:00 AM   #3057
ajh88
Drives: 2013 Firestorm FR-S
@Racecomp Engineering Plan to grab some RCE Yellows for an otherwise stock suspension and want to know what other suspension bits I need to achieve the recommended alignment. Camber bolts up front suffice?
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 02-06-2017, 01:18 AM   #3058
gramicci101
Off Topic
What are you doing with your car? Daily driving? HDPE? Autocross?
I have Yellows and camber bolts in the top hole. My front camber is maxed out at -1.7. You can run two sets of camber bolts or a camber/crash bolt combo and get more. This is fine for me for daily driving.
Your rear camber will be whatever it ends up as from lowering. Mine is -2.0 on both sides. If they come out grossly uneven or you want the ability to adjust, you'll want to get rear lower control arms. For myself, I'm happy with -2.
Old 02-06-2017, 10:26 AM   #3059
ajh88
Thanks @gramicci101. It's a daily and sees ~5 HPDEs a year.
2013 Firestorm FRS
Old 02-06-2017, 11:11 AM   #3060
@gramicci101 nailed it.
Camber bolts up front are cheap and make a huge difference, so I def recommend them.
Rear LCAs aren't 100% necessary for a mostly street car, but can be useful to dial things in just right. And sometimes you end up with uneven rear camber from the factory which is good to fix.
- Andrew
Old 02-06-2017, 12:32 PM   #3061
gramicci101
Off Topic
I would move the OEM bottom bolt to the top hole, put a camber bolt in the bottom hole, and get as much negative camber as you can in the front. It'll probably be somewhere around -1.5 to -2.0. Set the front toe to 0. The rear camber will be whatever it comes out to after lowering. Set the rear toe to slightly toe in.
Old 02-06-2017, 01:06 PM   #3062
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Using both gets more like -2.5
Old 02-13-2017, 12:44 PM   #3063
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I already have coilovers, upgraded front and rear end links, rear LCAs and toe arms.
What would be the next logical suspension upgrade(s) to compliment these parts?
Originally Posted by humfrz
I'm old and lazy
Old 02-13-2017, 01:38 PM   #3064
jvincent
jvincent's Avatar
Driver mod?
More seriously, there's not much left.
Have you already done all the various bushings?
Maybe different swaybars?
Old 02-13-2017, 01:48 PM   #3065
Clipdat
Proud of BOXER
Clipdat's Avatar
No, I don't have any bushings at all, also stock sways.
Originally Posted by jvincent View Post
Driver mod?
I'm old and lazy
Old 02-13-2017, 03:28 PM   #3066
Driver mod. Front control arm bushings. Rear upper control arm bushings.
- Andrew
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
