Old 02-14-2017, 02:30 PM   #1
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Where to buy aftermarket mid-pipe?
I currently have a Borla axleback (bolts right up to stock location) and wanted to upgrade just the mid-pipe as well. Any recommendation on where and what to buy? Would have to have a resonator, I want it quiet. Thanks.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-14-2017, 02:32 PM   #2
bababooey
Drives: BRZ SWP Limited -6MT
i know @WORKS has separate mid pipe (from their axlebacks) but cant say if it has resonator OR if it will fit with your existing hardware
bababooey is offline   Reply With Quote
Old 02-14-2017, 03:39 PM   #3
sugoi
Drives: 2015 BRZ Limited CWP
your stock midpipe is resonated.
sugoi is offline   Reply With Quote
Old 02-14-2017, 03:55 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
I know, I'm saying I want a larger diameter aftermarket pipe that is resonated as well.
Current DD: M235i
Old 02-14-2017, 04:25 PM   #5
Sarang
Drives: 2010 LGT
Nameless sells one.
https://shop.namelessperformance.com/3-midpipe-brz-frs/
Sarang is offline   Reply With Quote
Old 02-14-2017, 04:28 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Originally Posted by Sarang View Post
Nice, if only it was 2.5" though.
Current DD: M235i
Old 02-14-2017, 04:36 PM   #7
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Your stock mid-pipe starts out as 2.5" and the stock resonator is 2.5". The mid pipe necks down after the resonator to between 2" and 2.25". If you really want to keep it 2.5" all the way through, save yourself the money and find a local exhaust fabricator that uses mandrel bends, and they can run you a new 2.5" pipe from the back of the resonator to the flange on your Borla. It shouldn't cost you more than 2 hours of labor and a few dollars for materials. Hourly exhaust fabrication labor costs vary too much across the country, but I wouldn't pay a penny more than $100 to have that done.
The stock resonator is damn good.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 02-14-2017, 04:42 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Considering the number of people that practically give away their stock exhausts, this is the best advice.
Old 02-14-2017, 04:57 PM   #9
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Thanks for the mention
Our mid pipe works with the stock exhaust components (2013-2016 years) so will work with your axle back and does use a resonator.
Only thing that may be a curve ball is if your axle back has a thick flange which may result in you needing longer bolts.
WORKS Mid Pipe: http://store.worksmotorsports.com/WO..._p/146.211.htm
Cheers
WORKS is offline   Reply With Quote
Old 02-15-2017, 06:41 PM   #10
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Leg Sport also sells one in 60.5 mm (either 60 or 60.5, can't remember). Ft86sf carries it
Sent from my iDroid
Jajanken86 is offline   Reply With Quote
Old 02-15-2017, 06:51 PM   #11
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
The exact reason why you DONT buy axelbacks. When will people learn......?
Dr. BRZ is offline   Reply With Quote
Old 02-15-2017, 07:47 PM   #12
norcalpb
norcalpb's Avatar
Because catbacks are extremely expensive?
I had a Works axleback and a custom single exit before I ponied up for a full catback.
It's hard to justify the price for no performance gain. I only got mine to quiet down the rest of my exhaust which is not the case for people who don't have any aftermarket exhaust parts.
Old 02-16-2017, 01:40 PM   #13
8RZ
The Gunshine State
8RZ's Avatar
Because I bought it for $25 and it can always be upgraded. That's why.
Current DD: M235i
Old 02-16-2017, 02:45 PM   #14
bababooey
got ab-m because no lift, no garage and stands, didnt wanna fiddle with that much pipe. also it was most economical solution to satisfy desire for more loud
WTB aftermarket Over Pipe jdalny Want-To-Buy Requests 3 02-09-2017 12:40 AM
WTB aftermarket front pipe mjanmohammad Want-To-Buy Requests 1 02-05-2017 03:15 PM
WTB: aftermarket front pipe ndreim Canada Classifieds 3 01-17-2017 09:14 PM
WTB aftermarket mid pipe 08stiguy Engine, Exhaust, Bolt-Ons 8 12-05-2014 10:08 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 02:42 PM
