#2213 | |
Drives: Toyota 86 2017 TRD Modded
I have options though: Wait for EB to recalibrate their CARB tune and send it to me or I buy Delicious Tuning's calibration and roll with that. I'm doing the former now (as recommended by my installer) until EB gets back to us with a solution.
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
#2214 | |
Drives: '14 981CS, '99 NB1
Attached pic of clearance |
#2215 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
#2216 | |
#2217 | |
Drives: 2017 Toyota 86
Sent from my SAMSUNG-SM-G920A using Tapatalk |
#2218 | |
#2219 | |
#2220 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
THIS!!!! , and if it is your shop that figured it out, please share contact info so I may drive them crazy, I mean.....make my EBSC fit too.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#2221 | |
Drives: anything you let me
If so, this could be something older model owners need to be aware of. |
#2222 | |
Drives: Silver Coupe with a Boxer
Yeah, I would be very worried about that wire rubbing on the supercharger. Quote:
Since the connector on the control cable is different I doubt they would since it would require changing part of the wiring harness as well as the alternator. But weirder things have happened. |
#2223 | |
That said, if I ever take the blower off for some reason (service? idk)... I'll be filing down the edge of the manifold right there to get some additional clearance. If I had realized it was that close before we'd gotten everything settled, I would have filed it down before finishing the install. Getting the blower in place though was enough of a PITA that by the time that it "fit", it wasn't coming off.
#2224 |
My installer said, "The alternator had to be modified a bit by removing the clip for the regulator and bending the pin to clear."
No pictures on that, but you can imagine how it went
#2225 | |
#2226 |
CAR-AHOLIC
Well, I suppose I could bend the pin carefully. But do you know if when the clip was removed, did they hardwire the wire to the alternator or use a low profile type connector. Just curious, as I will likely try to modify my own and don't want to mess it up.
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
