Old 04-28-2017, 04:07 AM   #981
kzale1249
Drives: 2015 Scion FRS
Originally Posted by allowe View Post
You could've lost oil due to the rod going on u. Happened to my old spec v. Check your oil levels weekly from now on. It takes 10 seconds to do. As for the tune. I'm running the same tune as you but with an ofh specific tune. I doubt it's the tune because many would have had the same story. Keep us updated
Is it covered under warranty? If they say no, bitch and argue about it.
my car is still covered under warranty so far, i just took the car in to toyota earlier this evening. I hope why wont find out i had OFT tunes. If they did found out, I'm sure they're going to b*tch about the fact that i had the tune and the tune caused the damages.
Anyways, thanks for the advice! greatly appreciated!
kzale1249 is offline   Reply With Quote
Old 04-28-2017, 05:05 AM   #982
allowe
allowe's Avatar
Was it used or new? You should've flashed it back to stock right away it only would've taken 10 minutes and peace of mind knowing the can't bitch
allowe is offline   Reply With Quote
Old 04-28-2017, 05:26 AM   #983
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They might also say that you didn't check your oil levels frequently. Next time read the car's manual in detail.
Good luck!
Old 04-28-2017, 05:49 AM   #984
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
This is not a warranty situation. A warranty is for manufacturing problems, not abuse of the car. You could have read the manual, paid attention to the forums, joined FB car groups or just paid attention to your car. You should have been more proactive in caring for your car. When you tune your car, you have to be a lot more careful and take care of stuff your self. The upkeep of a tuned car is a lot more of a PITA than a stock car.
If you go 1500 mi over your OCI with a tuned car- too bad. Why would Toyota cover that under warranty? Because you can't afford a new engine? Too bad snowflake, here's a lesson in life and it's going to be very expen$ive.
guybo is offline   Reply With Quote
Old 04-28-2017, 06:25 AM   #985
LancePower
Drives: 2020 BRZ tS
Shouldn't he have gotten a Warning Light?
If not, that's a Manufacturer issue.
LancePower is offline   Reply With Quote
Old 04-28-2017, 06:33 AM   #986
allowe
allowe's Avatar
Open Flash Tablet - OFT TIPS Trick’s & FAQ
Some people really like making others feel like shit hence why the world we live in sucks. @kzale1249 go to the dealership and play dumb and blame it on them. Your car has a warrenty for a reason. If it's used, don't admit to it being tuned. They might think it's the previous owner. Depending on whether you live in Canada or the US. There is a lemon law and Canada has CAMVAP. Don't pay a dime until you've exhausted every possibility. The oil warning light should've came on, if the car loses that much oil in that many kms, your car is either burning oil or leaking which are both "manufacturers defects" if you live in Ontario I can come with u to the dealership. I've dealt with bs like this before and I have friends who dealt with CAMVAP before. If there is anything I can do to help, please let me know.
Crap I didn't see where u were living. Well if you need anything man let me know. Sorry to hear about ur car!
Old 04-28-2017, 09:08 AM   #987
new2subaru
Weight Weenie
Drives: 15 FR-S
To be down that much oil, I'd be looking for a leak somewhere.
That's a LOT of oil and it's not being burned!
Old 04-28-2017, 12:12 PM   #988
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Oil lights rarely give adequate warning in my experience, I also ran a car low on oil, I forgot to replace fill cap, luckily it was still sitting on the exhaust heat shield a week later after it sprayed 2+ quarts out the top. When the light came on it must have had <2 quarts left.
Some engines are designed with more durability for dumb owners, the FA20 isn't one of them.
Ok, lets trash the people for being blunt and honest and suggest committing fraud.
People like you are why warranty claims get denied at the slightest hint they can get away with blaming the owner.
Edit: In all honesty I'd be surprised it magically burned that much oil, either a lazy dealership trying to pin it on a customer or it wasn't properly filled up last time. Regardless if you don't know the status of your oil it's their word against your nothing, SOL as far as I'm concerned.
ineedyourdiddly
Old 04-28-2017, 01:49 PM   #989
Kodename47
Kodename47's Avatar
Drives: UK GT86
Oil warning on a lot of JDM cars is a low pressure warning, usually triggered by virtually 0 pressure. By that time, it's too late. But bearing issues will likely make the light come on.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-28-2017, 02:08 PM   #990
allowe
allowe's Avatar
Yea lets all shit on this mans day by stating the obvious on what he "should've" done....
Commit fraud? His car lost that much oil in such a small interval! Thats not fraud, that's a fuck up on whoever put oil in his car or it could even be a leak OR it could be burning oil. When I was shopping for my frs, I found one that had 40,000kms and only 1 oil chance on record. I immediately walked away from it but that ran like nothing ever happened ( and since you like stating the obvious, yes he could've done the oil change himself but I like everything to be documented).
Going back to the OP, check to see if Toyota did the last oil change. If so, you've got more ammo to fire at them with. Don't give up easily. Keep us updated, I'm dying to know how this will all play out.
Old 04-28-2017, 02:39 PM   #991
strat61caster
Fuck no. That's the responsibility of the car owner (checking the oil level after a fill), you pull that dipstick before you roll out of the service center.
At the end of the day you only have control over one person, trust but verify.
However I do agree with you that he should see if Toyota will bear the responsibility, being 1.5k miles late on a 7.5k interval oil change with modern synthetic oil shouldn't destroy an engine and if it legitimately burned off 3+ quarts there is something wrong. I'd bet something unusual happened here, if I was a betting man I'd think your hunch is right and the knucklehead that did the last fill might have underfilled or it was leaking out the drain plug (i.e. double/no/reused crush washer) or something else.
Low oil absolutely would destroy an engine regardless if the car had 400,000 miles or 4 miles.
ineedyourdiddly
Old 04-28-2017, 03:44 PM   #992
allowe
allowe's Avatar
Sorry if I seemed like a d*ck man. I would HATE to be in his position. I had the engine low on oil on my old Sentra spec v and threw a rod but lucky for me, I can take that block out and put one myself in less than a day and I got one for 500 USD.. also, I've never had someone work on my cars without screwing something up. Even my last oil change with Toyota. There was so much oil spilled in the engine bay, I could've fried some chicken on it lol.
Like @strat61caster said "trust but verify"
I really hope he figures out a way to put his twin back on the road. If I can help out in anyway, let me know!
Old 04-28-2017, 03:57 PM   #993
strat61caster
That's why I do my own work as well. I had to use an impact driver to get the drain plug off my mothers old car I've inherited, oil errywhere.
ineedyourdiddly
Old 04-28-2017, 04:14 PM   #994
allowe
allowe's Avatar
Jeez it must've been on pretty tight. I do my friend's cars and usually with a breaker bar, it comes right off. I'm just using up the free oil changes I got included with my deal (you can always squeeze something out of them) and finishing off my warranty with Toyota doing all my oil changes that way if anything screws up, it's on them.
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
