#365 | |
Drives: 2015 Scion FR-S
I do have my RPM higher under 32°, but it's never that cold here. |
#366 | |
Solar wind surfer
Drives: 2013 FRS
All the sample tables I see online have the degF in the titles. Do I need to convert values? Also some tables have the ignition timing set to -4 some to -8 and some +8. What's the difference? |
#367 |
Solar wind surfer
Drives: 2013 FRS
Never mind the headers are already converted.
Didn't notice it before |
#368 |
Solar wind surfer
Drives: 2013 FRS
So I flashed my ECU with the exact values in the guides picture (0 for ignition timing).
For some reason the CEL keeps popping up. I've cleared it 3 times now. Same code everytime. Is it supposed to be like that? The accelerator also feels a bit stiff. That might go away after a couple of drive cycle though. |
#369 | |
#370 |
Solar wind surfer
Drives: 2013 FRS
Yup that's the one. How do I disable it
#371 |
In romraider, open the tune, scroll down to dtc, and click p050b then click off.
I believe that's how you do it. @steve99
#372 | |
Drives: FT86
USA cars need this code disabled if you alter the post start ignition timing |
#373 |
Solar wind surfer
Drives: 2013 FRS
Sweet thanks guys. I actually found the thread on that.
So @steve99 what should I set my ignition timing to? There's so many different numbers online -8, -4, 0, +8. Also is the stiff pedal just cause I flashed the ECU and will go away once the car is calibrated? |
#374 | |
#375 | |
Solar wind surfer
Drives: 2013 FRS
![]() The numbers I was reffering to is for the first table (Ignition Timing Post Start). Some post has it as 0 (like the OFT tips and trick thread), some at -4/-6 (@steve99 in some post) and @troek had it at +8 in this thread. Also for the changes to the MAF Correction After Start tables, what do they actually do to the sound? Since it's so hot right now I don't I can hear the difference even if I flash them. Does it affect the droning noise at cold starts? Last edited by Ikaros; 05-27-2017 at 11:19 PM. |
#376 | |
Drives: FT86
The post start ignition timing changes the sound I find -4 give nice sound and very little drone/bark during startup. Maf offset is like choke in old cars adds fuel during warmup. If you get cold temps like below zero C then maybe leave 15 to 20 in the top two lines of the table on left hand side. If you leave the stock values car will still idle high even though you set idle tables to lower values |
#377 | |
Solar wind surfer
Drives: 2013 FRS
![]() So I made some changes. Does this look better? The MAF offset should only affect start ups, making sure the engine doesn't die right? Really wish OFT had the MAF correction after start tables on their site. |
#378 | |
Drives: FT86
yes that look good. these type of changes care very safe its only effecting the startup and first few minutes of run time, after that these tables, other than base idle are not used. id change you Idle target tables to be max say 1200 as well |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 03:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 07:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 02:35 PM |
