Old 05-23-2017, 08:19 PM   #3991
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Not_so_Breit View Post
So I have been admiring this kit for a long time and once I have enough saved I plan on taking the plunge. However I recently saw a video where this kit was installed and he had it tuned by a company and he was able to make about 250. He said that was lower then normal because of some cars dont allow for more timing. What does this mean and is there any way to know right now if my car won't allow for more timing? Not that 250 isn't alot but after seeing 260-270 and church automotive telling me they generally can make 270-280 I was hoping to get close to those numbers.
Thanks for any help possible.
Do you know what a stock car makes on each of those dynos?
Old 05-24-2017, 04:55 PM   #3992
gtengr
Drives: 2017 BRZ
This and stock vs aftermarket header are major variables.
gtengr is offline   Reply With Quote
Old 05-24-2017, 10:13 PM   #3993
Not_so_Breit
Drives: 2015 Subaru Brz Crystal White Pearl
stock I believe he told me about 165-175 for church
the youtube video i saw I believe he said 160 stock and 180 with header and tune
Not_so_Breit is offline   Reply With Quote
Old 05-24-2017, 10:13 PM   #3994
Not_so_Breit
160 stock and 180 with a tune and header
Old 05-26-2017, 05:39 PM   #3995
Sleepless
Drives: 2016 FR-S
Has anyone had issues with the bypass valve. After only a bit over a year (dozen+ track days), mine started leaking (not fully closing) and looks like it is melted/disintegrated with bits stuck in the valve. Surely these are designed to withstand the intake charge temps!?
Sleepless is offline   Reply With Quote
Old 05-27-2017, 08:58 PM   #3996
mrg666
pessimistic skeptic
mrg666's Avatar
Installed the Jackson Racing Supercharger with JR tune. I would call this a transformation rather than modification. Everything works so much better and the sound is awesome.
Thanks to Malen@86Speed and Oscar Jackson Jr. for all of their help.
Old 05-28-2017, 11:55 AM   #3997
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
I have a 2017 86 stick. I am thinking of the Jackson Racing kit like you did.
Any real world 0-60 or other performance numbers with the kit.
Thanks,
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
Old 05-28-2017, 01:23 PM   #3998
mrg666
pessimistic skeptic
mrg666's Avatar
Thanks,
Ron
I will post 0-60 number if I can find any time to go to a safe place for testing. This thread is full of all kinds of performance numbers, dyno charts, etc. Just check them out. I don't have any special mod to add to those numbers. I had written my personal experience in another thread as follows
Originally Posted by mrg666 View Post
... the improvement in acceleration and throttle response is immense. With JR tune, the engine is so much smoother in the full rpm range even at idle. There is no torque dip whatsoever and power constantly increases linearly upto redline. The car is totally transformed into an upper-class sports car. The power increase did not overwhelm the car; handling, braking, everything else are still great. I didn't want to do any other performance mod before JRSC and I don't think I will do anything else after this. I was thinking about installing a catback to add some rumble since all sound generator parts were being removed. But the supercharger whoosh is so good, I don't want any rumble anymore.
Old 05-28-2017, 03:05 PM   #3999
Ron B Avery
Thanks for your reply, I have read most of the posts on the Jackson supper charger on this forum. I have looked at most of the dyno charts, and read most of the driving impressions. But I have yet to see any performance numbers.
I have also looked on YouTube for a review by someone like Car and Driver ECT.
But I could not find anything.Thanks,
Ron
Old 05-28-2017, 04:39 PM   #4000
amcp1
Drives: frs
Curious about Sleepless's question as I intended to track my car with the JR setup as well.
amcp1 is offline   Reply With Quote
Old 05-29-2017, 02:04 PM   #4001
Sleepless
Drives: 2016 FR-S
I wouldn't let my issue hold you back; the JRSC is great for the track! Something unusual must have happened in my case. I'll be heat-wrapping the new valve ...
Old 05-29-2017, 05:03 PM   #4002
mrg666
pessimistic skeptic
mrg666's Avatar
original air intake duct
I removed the original air intake duct while installing the JRSC kit. Is this how others did? Is there a chance of getting water onto the air filter without it under heavy rain?
Old 05-30-2017, 07:46 AM   #4003
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
Who has these in stock, ready to purchase this week, looking for the C38 Kit, TIY. Would perfer to purchase from outside of CA as to not pay tax on it. PM if we can work something out.
GenRuleAThumb is offline   Reply With Quote
Old 05-31-2017, 05:29 AM   #4004
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Yup, Had exactly the same thing. Replaced mine with a cheap Aluminium unit (XSPower) off ebay as a stop gap while I ordered a new one. Still on the car today after numerous track days and daily driving. Never bothered to put the plastic one back in.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
