Old 06-17-2017, 01:04 PM   #1
xxdaooxx
Drives: 2017 Toyota 86
Will TRD springs RUB on my "17" 86
Hello I have a 2017 toyota 86 and bought trd springs. I asked my friend who has a 2014 scion frs that if he knew anybody. He asked around and people said don't do it because it will 'rub' im guess that means against the tire. He was saying just do coilover but I already bought these springs and want to use them since I had trd springs on my 2014 scion tc. If I do go ahead with installing the trd springs will I need to change the struts and coilovers to? I would think not since im not slamming. Would changing the tire size have to be done as well. I would hope not. Thanks for the feedback,
xxdaooxx is offline   Reply With Quote
Old 06-17-2017, 01:12 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
Do you have stock wheels/tires
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 06-17-2017, 01:16 PM   #3
stevesnj
stevesnj's Avatar
TRD springs are designed to work with stock wheels, tires and struts.I have them on my '16 with no issues and they aren't low enough to rub.From what it looks like no significant changes to the suspension setup geometry from 2013-2017 and I believe the part number is the same for TRD spring from 2013-2017. Check with the dealer to confirm.
2017 Part number .
http://www.trdusa.com/parts-detail.h...ring%20Springs
2016 Part Number
http://www.trdusa.com/parts-results....ring%20Springs
My 2016 Build thread
Old 06-17-2017, 01:22 PM   #4
Technically speaking the springs and struts are the coilovers. As said the TRD springs are designed for the stock set up but hey will still work with many other wheel and tire sizes. If what you are running for wheel size now are not causing issues then there is no reason why the TRD springs are likely to cause any. All will be fine.
Old 06-17-2017, 02:18 PM   #5
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
I have a 2017 86 as well. I have the stock wheels with the TRD springs with no problems. The only drawback is, you will need to take some steep driveways at an angle so you don't scrape the bottom of the front end.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
Old 06-17-2017, 02:25 PM   #6
Ron
Yep. And too fast over railway tracks will make you familiar with the bump stops in a real hurry.
Old 06-17-2017, 02:44 PM   #7
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
I have TRD springs on my '13, no problems. It's impossible to rub, the bump stop things prevent the springs from compressing enough. I live in SoFlo and our roads are very similar to any northern state that gets snowed and salted. Our tax money goes to more important things, like painting buildings.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 06-17-2017, 02:46 PM   #8
xxdaooxx
Yes it is stock everything right now.
Old 06-17-2017, 02:56 PM   #9
xxdaooxx
Thanks for the info really do appreciate it!
Old 06-17-2017, 02:58 PM   #10
Decep
Drives: 2013 FR-S Series 10
How much stiffer than stock are these springs? Because even mild ones like eibach pro kit will kill stock struts..
Old 06-17-2017, 03:44 PM   #11
gramicci101
Off Topic
You're confusing drop with spring rate. Aftermarket springs kill OEM struts because they lower too far and the strut has no travel left, so it bottoms out. But even then it depends on usage. I've been on RCE yellows and OEM struts for 50K miles with no issues. Others have needed new struts within 5K. People have run Eibach sportlines or RS-R superdowns for years with no problems.
Old 06-17-2017, 06:42 PM   #12
lantsalot
Derp
lantsalot's Avatar
I have a '13 with TRD springs, no rub. If that helps
lantsalot is offline   Reply With Quote
Old 06-17-2017, 07:30 PM   #13
Impureclient
Drives: 2015 FR-S
I got the TRD springs because my dealer said it's a Toyota part and was covered by the warranty so if anything goes wrong with the struts later, it's on them.
Old 06-17-2017, 07:36 PM   #14
I am on the stock struts with the Superdowns for 3 years and 100k miles and still no issues. Most of that is good condition highway travel though.
86 model, brz, frs, toyota, trd
Hypercoil 6" Springs, 2.5" ID, 400# - Brand New M0nk3y Brakes, Suspension, Chassis 6 07-05-2017 04:33 PM
FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports NvSnickers Wheels and Tires 2 04-04-2017 11:30 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
Eibach Lowering Springs (1" or 1.4") w/ Free Shipping and a 10% Rebate PhastekSport Brakes, Suspension, Chassis 4 12-09-2012 10:28 PM
