Drives: between cars...
What is this noise? Brake 'lsd'?
I've heard this noise at a couple of events but this is the best one that got captured on video. I'm running my 2017 Brz with Traction Control 'OFF' which I thought disables the brake lsd thing? So what do you think it is? It can be heard at: ~:35 and ~:45
[ame="https://www.youtube.com/watch?v=Ao3HYMnGQhk"]July 9th Alaska SCCA Autocross C-Street 2017 Subaru BRZ - YouTube[/ame] |
#2 |
Read the owners manual.
http://www.ft86club.com/forums/showthread.php?t=8212 2017's are slightly different. And search for "pedal dance" Traction control and stability control are two different things. |
#3 | |
https://view.joomag.com/subaru-brz-m...028204?page=11 But I'm not sure they are... |
#4 | |
And did you search "pedal dance" as previously mentioned? |
#5 |
Drives: '13 FRS - STX
CSG says the pedal dance is still required on the '17+ models, however I have no idea what the "problem" is based on the video and your description.
It "sounds" like you've just overdriven the car into the corner and it's skipping along the pavement potentially exacerbated by throttle and steering inputs. No car setting will change the laws of physics that you've tried to violate. (well, ok you might be able to tune it out with some fancy dampers, but it's much cheaper to drive the car the way that keeps it happy) fwiw ABS never shuts off if you're feeling the brake pedal pulse |
#6 | |
![]() well dang... I really thought I could avoid the pedal dance non-sense by going with a 2017 model... I guess we will see next month if I feel/hear any differences at the next event. |
#7 | |
I hear it too, what brake pads are you running? If it is the brakes activating (which would make sense for 'auto-LSD' to be working hard there) the pedal dance should cure it. Presuming you're doing the full 3s press to turn off the TC already. (based on the description in the OP you have read the manual for your car and are differentiating between the modes) Supposedly the slip light will flash when the car engages auto-LSD mode, if you can get a camera over your shoulder, on the driver window or on your helmet that could tell you right away if that's what's happening. Marketing has pulled the wool over the eyes of new sports car buyers for a long time, at least this doesn't render the car undriveable. And it could always be some other odd noise, these aren't bimmers after all with several hundred lbs worth of sound deadening. Read through the whole pedal dance thread, there are some foibles and I certainly struggled with adapting to it. |
#8 | |
I was doing the 3-sec hold and thought everything was off. The day before we ran the cars in a downpour and the car let me loose control the put it in a spin, so a fair bit of the system is disabled. I guess it really boils down to two concerns for me. 1) Did Subaru lie and the Brake LSD on or 2) is something loose that shouldn't be. |
#9 |
LMGTFY
Drives: 13 FRS, 91 Miata
Either I', missing something or your mixing up terminology.
WTF is a "Brake/Auto LSD"? AFAIK all are cars have is a basic Torsen unit. 100% mechanical Am I missing something? |
#10 | |
Toyota's traction control will still apply the brakes on the inside wheel if it has lifted as part of an "auto-LSD" function, there's more written about it elsewhere but the above is the effects and how to 'beat' them if you feel the need to. TC "off" really is mostly off, it won't save you unless it thinks there is something wrong with the car, rear wheels leaving the ground is apparently part of that equation. |
#11 | |
Drives: 2016 FR-S
#12 |
Drives: 2016 FR-S
Why would one want Brake LSD off?
Does the pedal dance turn it off?
#13 |
LMGTFY
@strat61caster and @Sleeples
Thank you for the info. Very smart idea if you ask me. Only big problem with the torsen being a lifted wheel making it an open diff. And if that is the case, yes, why turn it off. |
#14 |
@Sleepless @x808drifter
Per the CSG thread mentioned like 6 times already some feel that the EBD system prevents trail braking and weight transfer and the sudden application of brakes midcorner creates unexpected behaviour. (I haven't really felt that, trail braking for me) I honestly don't know if that's what op is hearing but I think it's worth experimenting with. Knowing if the slip light is flashing will determine if the car is doing something without having a test. |
| E-Brake issue "clunking noise" when pulling the e-brake while rolling. | Kinzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 06-20-2018 11:14 PM |
| Diagnosing a brake noise, need help.. | Subie_Nubie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 12-27-2017 03:47 AM |
| Brake pedal release noise | FR-YES | Issues | Warranty | Recalls / TSB | 4 | 10-19-2014 05:39 AM |
| Loud clunk noise when i pull E-Brake | Deagle50 | Issues | Warranty | Recalls / TSB | 28 | 09-20-2014 02:01 AM |
| rear brake noise | norcal_brz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-19-2013 04:25 PM |
