Old 05-11-2017, 01:24 AM   #211
steve99
Drives: FT86
Originally Posted by Yoshoobaroo View Post
I know, but the rear O2 sensor is used to affect long term fuel trims. That's why Ecutek recommends disabling LTFT when eliminating the rear O2 sensor.
The AF#3 is the correction associated with rwar 02 sensor its cruise fueling correction. Its the one you set to zero to disable
You could disable ltft if you wanted to but their no real need to ltft is average of stft over time this is all done of the front o2 sensorcwhich is primary fueling sensor
Tuners will often disable ltft if runningning flex kits so it doesnt fight with flex sensor corrections to fueling
Old 05-11-2017, 02:23 AM   #212
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Thanks for clearing that up! Are you saying it's often done cause the chance of it fighting the ECA outweighs the benefits of LTFT, or that it's to compensate for not completely fine tuned maps, which would cause it to fight the ECA sensor?
Old 05-11-2017, 05:22 AM   #213
steve99
Drives: FT86
Yeah essentialy you have two systems trying to correct fueling
Some tuners disable ltft some dont. Some run full time closed loop or their own fueling strategys
Old 07-10-2017, 05:36 PM   #214
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
It's been awhile, but we've got some new tune updates for everybody running our naturally aspirated tunes! As usual, these updates are $65 to update to for current customers running older revisions.
Current versions and their respective improvements are as follows:
NA Stage 1 - V7.00
- Improved power output, especially top end.
- Closed loop fuel control under high load conditions.
- Smoother drivability in low rpm, low load areas.
- Improved throttle control.
- Available soft rev limiter.
NA Stage 2 - V7.50
- Improved power output across the board, but especially top end.
- Closed Loop fuel control under high load conditions.
Ace Header Specific - V8.00
Additionally, ALL tunes have now been updated to the most current RaceROM patches to support the new EcuTek ECU Connect Bluetooth features.
Some ROM versions will also offer a bump in fuel economy, depending on your current tune version. Email me directly at sales@delicioustuning.com.com for more details.
Other updates include:
- All of our Flex Fuel kits, MK 1 and MK 1+, now operate on a 0.5-4.5V signal to the Rear 02. This gives us increased room for error reporting. It also provides more room to implement extra safety features on the tuning side of things, whether we're tuning it or anyone else.
- Flex Fuel kits now come with updated hardware, and all kits currently sold come default as iPhone and Adnroid compatible.
- Current kits now operate on BTLE instead of Bluetooth Classic for better compatibility with today's smartphone's and their operating systems, as well as decreased battery consumption when using the app.
- We have the iPhone app up and running, with several beta testers running around to finish validation for us while Apple goes over final approval to put it up on the App Store. We expect the final App to be approved and released for everyone very shortly, by the end of this month (July '17) at latest.
More info to come soon!
Sincerely,
Zach
Old 07-19-2017, 02:30 AM   #215
byun
byun's Avatar
Drives: 2015 BRZ CWP
Have been running the updated tune for a week now. Major difference in power mid range to redline. Car ran great at Sonoma this past weekend.
Awesome stuff as always. Thanks guys!
byun is offline   Reply With Quote
Old 08-03-2017, 05:25 PM   #216
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Sincerely,
Zach
Any updates on the Apple APP ? Thanks!
Silverfox is offline   Reply With Quote
Old 08-10-2017, 12:38 PM   #217
DeliciousTuning
App is done. Waiting on Apple to put it on the App store. Out of our hands at this point.
Old 08-10-2017, 01:05 PM   #218
Silverfox
Silverfox's Avatar
Damn, their approval process is ridiculous. Thanks for the update! look forward to downloading it.
Old 08-14-2017, 09:31 PM   #219
DeliciousTuning
Hi everybody,
We (and our flex fuel kits) are a top 15 semi-finalist in SEMA Launch pad and we need your support in the Facebook voting contest for us to proceed to the next round.
Voting takes less than 30 seconds and you can only vote once.
So let's show SEMA how strong this community is, while also sending a message that ethanol fuels are not the enemy.
So vote Delicious, Pierce and for corn made ethanol-blend fuels!
Click here to vote now
Thanks!
Old 08-16-2017, 05:48 PM   #220
Jasonbot
Jasonbot's Avatar
Drives: scion FRS
Delicious App for iPhone is now on the app store!
Jasonbot is offline   Reply With Quote
Old 09-20-2017, 08:04 PM   #221
DeliciousTuning
In response to customer demand, Delicious Tuning has completed and released the company’s iPhone-based (version 10.2 and newer) data-monitoring app for its flex-fuel systems. Now, customers of all stripes – whether Android or iPhone-powered – can use their mobile device to directly monitor their Delicious Flex-Fuel kit, track fuel pressure and ethanol content, and data-log minimum and maximum values in real-time.
The iPhone app has been an ongoing challenge for Delicious. Apple is historically protective of its app store, and finding a working balance with them (without making this product cost extra) was an exercise. It was worth the effort: the improved efficiency of Bluetooth “LE” chips in new iPhones doubles the app’s speed, quadruples its range, and improves device connectivity.
Because Delicious Tuning has sold almost 1000 flex-fuel kits, there will be legacy parts updates to chase down. As always, the company will stand behind their product. If you paid for an early iPhone-paired flex-fuel kit and can verify it, Delicious will need to update your firmware and hardware (at our cost – give us a call). If you’ve recently bought a flex-fuel kit and would like to make it iPhone-friendly, contact Delicious for how to do it. Note: some of the company’s newest flex-fuel kits are already iPhone-capable, (SN: 0739 & up) so download the app and give it a try. If your kit is below SN 0739 and you did not originally purchase an iPhone compatible kit, it will need to be sent in and upgraded via this link: https://www.delicioustuning.com/node/149
Another option for folks on MK 1 kits that are also interested in the iPhone update would be through our MK 1+ Update and the ECA Core Exchange option, available here: https://www.delicioustuning.com/DESS_Mk1_Plus_Upgrade
Ordering the MK 1+ along with a fresh core ensures that the new ECA you receive will be iPhone and Android cross compatible out of the box.
Sincerely,
Zach
Old 09-27-2017, 09:28 PM   #222
Scootertribe
Drives: 2013 Scion FR-S - MT
I purchased a flex fuel kit this week, will it come with all of the new updates and features? Thank you (Android user)!
Scootertribe is offline   Reply With Quote
Old 10-04-2017, 12:54 PM   #223
DeliciousTuning
Any kits purchased roughly after April of this year will have iPhone compatibility out of the box.
-Zach
Old 12-15-2017, 11:10 PM   #224
DeliciousTuning
Hi Everyone,
Say hello to my little friend. He is still in the prototype stages but you kept asking for a gauge to work with our current line of Flex Fuel Kits and here it is. This unit will work with all Delicious Tuning Flex Fuel Kits roaming the marketplace.
[ame="https://www.youtube.com/watch?v=1DfbygQbBbs"]Flex Fuel Gauge and Something Else... - YouTube[/ame]
The other cool option we are debating on is boost control through the gauge. The feature would be a way of setting up boost control based on ethanol content and the user has full control of those settings. Let us know what you think and if you have any suggestions we are always listening.
Planned release is first quarter 2018.
Happy Holidays!
William Knose
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 09:37 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 01:01 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
