Old 09-18-2017, 01:53 PM   #155
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by JDLAutoDesign View Post
Stock engine with 2017+ Intake manifold
JDL V2 UEL Kit with Garrett GT2860rs (Disco Potato)
Delicious Tuning Flash N Go ( No revisions yet )
Delicious Tuning Flex Fuel kit
DW 700 CC injectors
Intake Pump
12psi on e85
This is commonly known as a wall... a torque wall!
I like driving!
86 South Africa is offline   Reply With Quote
Old 10-01-2017, 05:05 PM   #156
TRACE_on
TRACE_on's Avatar
Drives: 2023 GR86 - Track BRed Premium 6M
Previous Dyno: http://www.ft86club.com/forums/showp...&postcount=126
- Greg / TRACE_on
- Dynosty built motor with 10:1 compression
- Forced Performance FP Black upgrade for GReddy T620Z
- Omni 3 Bar MAP Sensor, Tial Sport Q 50mm Blow-off-valve
- Deatschwerks 900cc Injectors, DW65C Fuel Pump
- Motiv Concepts Over Pipe 2.5", Motiv Concepts Test Pipe 2.5", GReddy Supreme SP Catback 2.5"
- Clutchmasters FX400 Full-Face Disc aka "8-puck", DSS 600hp Axles, DSS Aluminum Driveshaft, IS300 3.73 LSD, Velox Clutch Fork
- E85 @ 21 psi: 448whp / 370wtq (blue lines)
- 93 @ 16 psi: 382whp / 299wtq (red lines)
- Tuned by Hal @ Dynosty. Ran out of fuel pressure on E-85, need to increase fuel pump flow and take back to dyno.
STR also-ran
TRACE_on is offline   Reply With Quote
Old 10-02-2017, 12:06 AM   #157
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
PTUNING GTX2867
PTUNING GTX2867 Kit
- Stock motor
- 850cc Injectors
- EBCS
- ACT Stage 2 Clutch
- 3" Exhaust
- PTUNING 4-1 Header
- PTUNING FlexFuel
- Dyno tune by Toan @ptuning
SpectreRT is offline   Reply With Quote
Old 05-26-2018, 08:07 PM   #158
mrloko
Drives: 2017 Subaru BRZ
DW 700 CC injectors
Intake Pump
12psi on e85
where is the dyno???
mrloko is offline   Reply With Quote
Old 07-05-2018, 09:25 PM   #159
Colin86
Drives: 86
Edelbrock w/ stock pulley
DW300c fuel pump and DW 700cc injectors
Delicious D box, flex fuel kit, and Edelbrock tune
Gruppe-S UEL header and over pipe (both coated)
E85
Stock front pipe, cat back, and clutch
327whp and 243wtq
Sorry for potato quality photo. Note Delicious performed their V25 revision on the car following this dyno and it feels even better than it did when it put down these numbers.
Huge shout out to Nik and Hal at Dynosty for being super chill and for Zach for all of his help with dialing the tune in!
Colin86 is offline   Reply With Quote
Old 07-08-2018, 07:23 PM   #160
EchoHotel
Drives: 2013 FR-S Hot Lava
13 Rotrex FRS
- Erik
- Kraftwerks C30-94 High boost 30mm
- E85 1000cc injectors 340lph pump
- 18psi-20psi
- Fastech built motor 10:1
- Delicious Tuning
Run video
@CSG Mike
EchoHotel is offline   Reply With Quote
Old 07-09-2018, 06:17 AM   #161
CSG Mike
CSG Mike's Avatar
Since when do C30's do 18-20 psi?
Old 07-09-2018, 09:05 AM   #162
EchoHotel
Since now, get smart again Mike what happened too “you won’t see over 320?”
Old 07-09-2018, 12:57 PM   #163
CSG Mike
CSG Mike's Avatar
Sorry, the dyno is still meaningless without baselines.
I could show you many dynos similar to yours without a built engine, on less psi, which are equally as meaningless without a baseline.
Here's how a proper dyno looks, with baselines.
My car makes 360whp, on just 10.5 psi at peak. I'm 100% sure my T518Z turbo is not 80% more efficient than your C30-94.
Bottom = stock.
Green = ACN91 5.5psi at peak hp
Pink = E70 5.5psi at peak hp
Orange = 10.5psi at peak hp
Old 07-09-2018, 01:22 PM   #164
EchoHotel
Bottom = stock.
Never felt the need to dyno my built engine frs Without supercharger on it 🤷🏼*♂️
Old 07-09-2018, 01:25 PM   #165
CSG Mike
CSG Mike's Avatar
Originally Posted by EchoHotel View Post
Never felt the need to dyno my built engine frs Without supercharger on it ����*♂️
The dyno claims 185whp with a bolt-on B16 (160 crank hp stock).
https://www.instagram.com/p/BjuxXD-BmXd/
Know what the problem with that is? The B16 is a very, very well documented engine. We all know how well (or not well) honda B and F engines respond to bolt-ons (they don't really).
Lets say it really made 185whp. If the dyno loss is 15%, then its 217.65hp at the crank. A whopping 36% gain with bolt ons and a tune!??!? At 1.6 liters, that little B16 is making 136.03hp per liter. Holy shit that's more than any production NA car ever made. Ever. To this day.
Sorry, but I bet I can pull buslengths on you with "20 less whp".
Old 07-09-2018, 01:44 PM   #166
EchoHotel
Here
Old 07-09-2018, 01:49 PM   #167
CSG Mike
CSG Mike's Avatar
Good to know he can throw a few bolt-ons on a 30 year old engine, and tune the engine to make more hp/liter than a 458 Speciale.
He should be working for a race team or something. The guy is a genius!
I love how every dyno posted, never has a baseline.
Old 07-09-2018, 02:05 PM   #168
EchoHotel
that civic had ported head, which is not a bolt on. anyways
He did tune Fastech Racing’s 7.8’s GTR but who knows guess he’s a hack because you say so?
By the way this is a delicious tune, only thing he has in this is strapping it to there dyno
For me.
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 11:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
