Old 10-26-2017, 11:17 PM   #393
ArCha
Drives: 2013 Subaru BRZ SWP
Originally Posted by johan View Post
Sweet, any pictures of it installed that show how things fit?
Sorry about the slow response, been a bit busy.
I replaced the Aeroquip hoses with Vibrant hoses that were done by a friend. He's got a bunch of extras, if anyone wants a set made let me know.
Temperatures looked pretty good. They held steady and the oil temps were way lower than before. Ironically looking at some old logs these are almost the same as sitting on the highway with cruise control on. I may not be a track star but I'm sure it's getting a bit more of a workout.
ArCha is offline   Reply With Quote
Old 10-27-2017, 01:51 AM   #394
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Really happy Zach got it all taken care of for you! I was following up with him to see how your e-tuning was going, and mentioned to him that you weren't too far from them, and custom tuning could happen. Sounds like it was the best choice!
Originally Posted by PhyrraM View Post
This a final follow up on the kit install. The install has been completed for about 4000 miles with zero mechanical issues. Everything from Harrop worked as intended and advertised.
For those that may still be on the fence between the Harrop and Edelbrock kits - one so far unmentioned advantage to the Harrop is that it can be installed without taking the bumper cover off.
I did spend the last few weeks working with Zach at Delicious Tuning to finalize the tune. We went through about 7 revisions on the tune (2017 BRZ manual trans). Zach was dealing with a tip-in knock issue and a hot stalling issue. It did drive very well outside of those two issues. I ended up taking the car to Delicious (about 80 miles away) for him to look at in person. After about an hour Zach had both issues killed and the car runs as well as it ever did from Subaru. Strong as hell, broad torque curve, easily controllable both from a stop and at speed.
Then we filled up on E85.......No idea why folks want more for a street car. I must be getting old. This is a completely STOCK - down to the exhaust - 2017 BRZ with ONLY the Harrop kit, Delicious flex fuel kit and Delicious/Ecutek tune as mods. It is now the definition of "Point and shoot". It can overload the traction control at will. I will need to learn to drive it again before attempting Track mode outside of a controlled environment.
Props to Subaru, Harrop and Delicious. For less than $40K it's nothing short of a Cayman with a basic interior. Which was kinda the goal.
The Racers Line is offline   Reply With Quote
Old 10-27-2017, 01:08 PM   #395
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What’s the hose that is going under the air box and next to your belt?
Old 10-28-2017, 02:05 AM   #396
ArCha
PCV breather line, it actually goes into the back of the air box.
Old 11-09-2017, 03:46 AM   #397
johan
Drives: '14 981CS, '99 NB1
johan is offline   Reply With Quote
Old 11-09-2017, 04:55 AM   #398
retrofit
Drives: Toyota 86
That sucks
So the belt stayed on after the portion on the ground tore off?
Any further damage done?
Notice your belt kinda looks wider than your pulley. Maybe it's just the angle
Sent from my SM-G930F using Tapatalk
retrofit is offline   Reply With Quote
Old 11-09-2017, 02:46 PM   #399
johan
Originally Posted by retrofit View Post
That sucks
Top picture is the belt after removal.
A rib of the belt esploded and then the belt started walking off the pulley. That's what you're seeing, it mid-stride.
I don't even have 3000 miles on my setup. Just over 4000 miles on the car itself.
Old 11-09-2017, 11:08 PM   #400
Irace86.2.0
How much power? How’s the tensioner? Were you driving hard at the time?
Old 11-10-2017, 01:13 AM   #401
Irace86.2.0
ALso, I’m pretty sure the kit is defective. You should probably sell it to me.
Old 11-10-2017, 01:41 AM   #402
johan
Car is making ~120hp over stock.
Car has 4000 miles, how do you think the tensioner is?
It happened on startup.
Car had just been driven a couple miles and parked, not even warmed up - was running fine with no weird sounds. Started back up and WAP WAP WAP.
Yup, kit is totalled. I'll sell it to you for the low low price of $10k.
Old 11-10-2017, 02:10 AM   #403
Irace86.2.0
I found this old thing:
http://beltguy.com/National%20Dragst...%20Article.pdf
I feel like alignment and tension are the two biggest possibilities for belt failure. I doubt the belt material failed, but that could be.
Old 11-10-2017, 11:43 AM   #404
gtengr
Drives: 2017 BRZ
I'd guess the belt got nicked somewhere during shipping or the install.
gtengr is offline   Reply With Quote
Old 11-10-2017, 02:14 PM   #405
johan
That is a different type of belt. Tooth vs Rib.
Old 11-10-2017, 02:40 PM   #406
sachu
Drives: rocketship
DAmn! That sucks!! WEird that it would happen on startup though isn't it? WOuld normally expect something like that happening when under WOT under full boost.
sachu is offline   Reply With Quote
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 05:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
