Old 01-22-2018, 04:09 PM   #1289
maicolp
Drives: toyota gt86 1st edition
the bolt you are referring is this?
maicolp is offline   Reply With Quote
Old 01-22-2018, 04:17 PM   #1290
jasonojordan
Drives: 2013 satin white brz limited
I did the ones on the inside of the subframe.
jasonojordan is offline   Reply With Quote
Old 01-22-2018, 04:19 PM   #1291
maicolp
i'll try to slide in the overpipe wiggling it...
one big problem is... i'm alone doing this
Old 01-22-2018, 04:23 PM   #1292
jasonojordan
Its doable. I did mine on my own.
Old 01-22-2018, 04:23 PM   #1293
churchx
churchx's Avatar
Drives: 2014 GT86
maicolp: imho you'll have much harder and longer to work if you'll do w/o engine rising, especially, if you are only one doing it.
But should rising engine be that hard? Just put some stand below engine by pan, undo mounts .. and lower car a bit .
Old 01-22-2018, 05:00 PM   #1294
top quality, if you ask me.
super fast and precise.
can't wait to throw them on!
Looks like they welded your header a little out of focus.
I am disappoint.
Old 01-22-2018, 06:17 PM   #1295
johan
Drives: '14 981CS, '99 NB1
I am disappoint.
#totaled
johan is offline   Reply With Quote
Old 01-23-2018, 12:22 AM   #1296
FunnyGopher
Drives: 2015 BRZ Limited
Delicious finished my Ace 350, Ace FP, Touring 86 tune today! Overall I really like it. Zach was telling me my setup was making a bit less power than other's with the ACE setup, but it's still amazing. Highly recommend. I'm putting the car on a dyno Saturday, and will post the before and after charts when I get them.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 01-25-2018, 06:49 PM   #1297
n0thing
Drives: Subaru BRZ
I see that the 150 pushes more HP on the top end at the expense of low end torque, but how bad is it really on the streets? noticeable vs 350?
n0thing is offline   Reply With Quote
Old 01-27-2018, 11:54 PM   #1298
FunnyGopher
Here's the before and after I promised of my setup.
Travis, the owner of the dyno, was telling me his reads a bit lower than most. For reference though, here's a comparison of a friend of mine who ran right before me, running with the typical UEL, decatted exhaust, and e54 tune. I'm still on 91.
He made more than I did, but not by much. I'm starting to think my next upgrade will be a flex kit.
Old 01-28-2018, 12:01 AM   #1299
Lantanafrs2
Drives: 2013 frs red
That's a nice chart. Congrats!
Lantanafrs2 is offline   Reply With Quote
Old 01-28-2018, 12:03 AM   #1300
Lantanafrs2
At the risk of being flamed, do you think it might do better with stock intake and throttle body?
Old 01-28-2018, 09:54 AM   #1301
bfrank1972
Drives: 2013 FR-S Argento
What the heck was going on with the top end of your "before" curve, the drop off on the top end makes me thing something was wrong with whatever setup you had before. Even a stock header & tune should not drop off like that.
Old 01-28-2018, 11:20 AM   #1302
Lantanafrs2
Might be where he let off.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
