Old 02-01-2018, 05:07 AM   #71
Dammod
Dammod's Avatar
Drives: .
I'm thinking that if I ever get a timing cover leak, I'm just going to tape a sponge over the leak and change it every now and then ...........
Agreed, in hindsight I would have done that...At the time I thought I might as well make use of the warranty left on the car to get as many niggles sorted as possible.
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 02-01-2018, 01:21 PM   #72
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Oh wow.. Now I'm nervous to go to my 2nd timing chain cover leak repair. the initial leak was worse and currently oil is just sipping from the dipstick area I think as far as my check but reading this now is making me have 2nd thoughts. 2014 brz here w/ 38k miles in the odo. So I have an appt to bring the car in on th 8th? just keep the appt and have them fix it?
tintumz22 is offline   Reply With Quote
Old 02-01-2018, 03:32 PM   #73
I have found over the years, even before I got old and lazy, that sometimes it's best to let certain niggles go unsorted ......
Like the plumbing in an old cabin in CT.......
And a leak in the shower stall of my daughters bathroom ......
Old 02-01-2018, 03:34 PM   #74
Hopefully a new "O" ring on the dipstick tube will fix it.
Old 02-01-2018, 04:56 PM   #75
tintumz22
tintumz22's Avatar
I hope so too. The tech that did the inspection said and they will remove the whole timing cover and reseal and change all the O ring that's in there. The tech was kind enough to come out and talk to me to explain the whole procedure per my request.
Old 02-02-2018, 02:14 AM   #76
Dammod
Dammod's Avatar
Drives: .
I am learning this too now....
If I were you, I would drop them an email warning them about potential oil starvation after changing the timing chain cover - just so that you have it on "paper" that you warned them, since we all know how dealers like to point fingers and pin the blame on other things.
Old 02-05-2018, 06:21 PM   #77
Ayoitszritchie
Ayoitszritchie's Avatar
Drives: '14 DGM BRZ Limited 6MT
3K miles later leading up to today after my 2nd leak warranty job. My car just spun a bearing too and I just got back home from sropping it off at the dealer. Waiting to see what they say. I say go ahead and get it all “fixed” under warranty while you still can before you have to pay out of pocket. My friend had the similar issue and he was out of warranty and the dealer only wanted to cover 50% of the cost it was to put in a new block.
Ayoitszritchie is offline   Reply With Quote
Old 02-05-2018, 07:41 PM   #78
tintumz22
tintumz22's Avatar
wow. this is just wow. A fix that leads to another problem eh? aint that a good news.. smh. well, yeah just bring them the car to for the fix and let them handle it. I'll be writing an email for the advisor regarding the potential problem it will have few miles later after the fix just to put it on documentation. Thanks for the heads up!
Old 02-13-2018, 12:56 PM   #79
tintumz22
tintumz22's Avatar
Update: They did not need to reseal my timing chain cover. They changed dipstick o-ring and they applied some leak check spray per receipt. No sign of any leak so far. Knock on wood it stays like that.
STOCK MOTOR 3k Anthony7515 Engine, Exhaust, Bolt-Ons 16 11-25-2014 04:48 PM
Stock Motor Cross Want-To-Buy Requests 2 08-01-2014 07:47 PM
Spun out and hit a curb... JohnAyySays Issues | Warranty | Recalls / TSB 54 12-09-2013 11:59 AM
Avoided deer, spun out, alignment needed? gatorbushmen Scion FR-S / Toyota 86 GT86 General Forum 30 07-28-2013 12:14 PM
Spun out now a CEL Noob4Life Issues | Warranty | Recalls / TSB 10 03-31-2013 12:02 AM
