Old 08-28-2015, 12:26 PM   #29
Starkiller
Drives: 2013 Scion FR-S 10 series
Sweet!! WE NEED MOAR DYNO!!! Lol
Sent from my iPhone using Tapatalkoryopu
Starkiller is offline   Reply With Quote
Old 02-26-2018, 11:34 PM   #30
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Reviving the thread to share my recent tune.
Engine mileage:- 90,000km (~56,000 miles)
HKS Panel Air Filter
Tomei UEL Headers
HKS Spec-L Cat-back Exhaust
Toda Clutch and Lightened Flywheel
Motul 8100 5w-40
Brzerker is offline   Reply With Quote
Old 02-27-2018, 02:56 AM   #31
PuslarBrrrz
Courtesy of @Lincoln Logs
E85 OEM header vs E85 OFT UEL
PuslarBrrrz is offline   Reply With Quote
Old 02-27-2018, 07:03 AM   #32
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
El Cheapo budget build. Gutted header and FP, Injen intake, OFT OFS E85 Stg 2 tune.
They took a long time to find the signal wire for RPM and my IAT was over 120 (thier fan was useless) I'm sure it would have been over 200 HP, but the engine pulls timing with the IAT so high. Ah well, for the money, the numbers are great.
guybo is offline   Reply With Quote
Old 07-20-2018, 10:33 AM   #33
vagthomas
Drives: Toyota GT86
Dynoed in Dyna - Pack
Power in whp
Dotted line is stock (prior mods)
Mods:
K&N Free Air Flow Filter
HKS Catted Header
Custom Tuned (by ECOSPEED - Greece) with ProEcu (ECUTEK)
Quad Tip TRD High Response Muffler (actually that didnt make any difference )
Rest car still stock
vagthomas is offline   Reply With Quote
Old 10-02-2022, 05:29 AM   #34
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
1st dyno pic are “stock” (Mishimoto inlet tube and STI axle back exhaust) runs.
2nd dyno pic is with the HKS GT-Spec catted header installed and a BMC drop in air filter comparing it to stock.
An extra 11.4kW (15hp) at the wheels and more low end torque. If you’re sitting on the fence about getting a header and tune, I’d recommend it.
Dirty Harry is offline   Reply With Quote
Old 10-04-2022, 05:46 PM   #35
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
1) Custom Tune by Steve99
2) E85
3) PTuning Headers, JDL midsection. Stock exhaust pipe bolted to race muffler.
4) TRD Intake
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 11-10-2022, 09:54 AM   #36
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
That flattened torque curve (+ 25 lb-ft at 4K rpm), I suspect, is the key to your happiness, more so than the 15 hp overall gain.
LRNAD90 is offline   Reply With Quote
Old 11-11-2022, 03:01 AM   #37
Dirty Harry
Yeah 100%, the improved low down torque is the winner here. You do notice the extra power a bit up top, but no where near as much as the low end torque. The tuner did a really good job with it. It is just a linear pull to redline and better up hills and putting around town. It sounds better too, the HKS headers are a nice compliment to the car.
BTW the torque measurement is in newton metres (Nm) so less than 25 lb-ft, around 18 lb-ft, so still significant.
Old 11-11-2022, 01:20 PM   #38
LRNAD90
Opps, wasn't paying attention to the scales, the flatness of the torque curve had me mesmerized I guess. The HKS Header you are running is an EL design, right?
Old 11-11-2022, 10:21 PM   #39
Dirty Harry
HKS GT-Spec, equal length and catted too.
https://www.hks-power.co.jp/en/produ...haust/db/15582
Being legal was a big requirement for me, so I went catted headers. I could of gone catless for a lot cheaper.
NA FR-S/BRZ Dyno Thread myEFispissed Engine, Exhaust, Transmission 11 09-02-2023 10:28 PM
Starkiller's 10 Series Stuff and Things Build**Now with Dyno video and graph Starkiller Member's Car Journals 22 08-19-2015 08:17 PM
What are these spikes and dips in my dyno graph from? FRSFrank Software Tuning 1 05-03-2014 12:44 AM
Completed!! FBM 700+HP Build Dyno graph & Vid inside FullBlown Forced Induction 214 03-31-2014 02:56 PM
Turbo Dyno Graph? wootwoot Forced Induction 3 09-26-2012 06:40 PM
