Old 04-09-2018, 08:10 PM   #575
hestekinj
Drives: 2014 BRZ - WRB
Updated B01C
Originally Posted by elBarto View Post
Use this definition, it's fully up-to-date A01G, modified for a 700C.
V4 OFT 700C Def
Use only with the V4 tunes! Remove any other 700C def you have in RomRaider!
Do you know if there are updated B01C definitions too?
Thanks!
hestekinj is offline   Reply With Quote
Old 04-10-2018, 05:38 AM   #576
Totalrecall
Drives: frs
V4 OFT 700C Def
Oh wow that added the extra tables . Thanks! How come oft official downloads dont come with these updated definitions?
Totalrecall is offline   Reply With Quote
Old 04-10-2018, 11:10 AM   #577
bababooey
Drives: BRZ SWP Limited -6MT
Thanks!
you're in luck. I have b01c as well. I took the def Steve posted to first page of V4 release thread and adjusted to allow me to modify the generic v4 tune.
bababooey is offline   Reply With Quote
Old 04-10-2018, 01:49 PM   #578
elBarto
elBarto's Avatar
Drives: Toyota GT86
I think those are still the old def's of the v1.x tunes. Since then alot of tables have been discovered.
Thanks!
This is a B01C:
B01C V4 def
But it's probably the same as bababooey's upload.
Same principle, only for V4 tune and remove any other B01C def.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 04-10-2018, 06:47 PM   #579
hestekinj
Thank you!
Awesome! Thank you very much!
Old 04-10-2018, 10:55 PM   #580
jerryzilla
jerryzilla's Avatar
Drives: 2016 Subaru BRZ Series.Hyperblue
Any way to get the car to pop with the overrun method while in neutral? i changed base idle timing (neutral) to -8 from 2500 onwards, but no pops
jerryzilla is offline   Reply With Quote
Old 04-10-2018, 11:09 PM   #581
D_Thissen
D_Thissen's Avatar
Originally Posted by Vin View Post
Small update on this. First I've tried like @eddieflyinv suggested, mostly to find the sweet spot:
+10 @ 2500
+5 @ 3500
+2.5 @ 4500
0 @ 5500
This produces some nice burbles, but also still some harder pops if you really want to. Sweet spot seemed to be around 3-3.5k rpm, so around +6 I assumed, so:
Then I tried +6 constant, which was to loud in the low revs
Also tried +10 constant, which was very nice in the low revs, but didnt produce any sounds above 5k rpm, so it seems the sound differs with RPM also, even if keeping the timing constant. For now I'll settle with the +10 +5 +2.5 0 settings posted above, might try something like +10 +5 +5 +5 or so in the future, but don't think it will make that much of a difference.
Are you still running this setup? Would you be able to post a video of how it sounds? Sorry if you have and I missed it.
Old 04-11-2018, 11:11 AM   #582
MrStickers
Drives: 2013 Subaru BRZ Premium
V4 OFT 700C Def
Does anyone have a v4 OFT A01G modified for A00C (BRZ USDM)?
If not, can't i just change the calid in hexeditor/dreamweaver, save it, and use that as the definition file? Do I have to change the "make" "model" in it as well or can i just leave it as Toyota GT86?
2000 BMW 323i
MrStickers is offline   Reply With Quote
Old 04-11-2018, 11:41 AM   #583
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
I've been running +5 from 2500 rpm for the last 6 months, works like a charm and produces a nice pop. However friends tried the same, but got almost nothing (on stock exhaust) or super loud pops on exhausts with less dampening, so it really seems to depend on setup, I have a video somewhere, will share it soon
Vin is offline   Reply With Quote
Old 04-11-2018, 01:04 PM   #584
hestekinj
In your experience, does the +5 from 2500 produce more pops, and the +10, +5, +2.5, 0, more burbles?
Old 04-11-2018, 01:55 PM   #585
bababooey
ive been using -5 to -10 this whole time. I may have to go to the positive to see the reaction.
Old 04-11-2018, 04:54 PM   #586
Vin
Vin's Avatar
This is -5 , higher frequency of pops and also the sound is higher tone, popcorn:
https://photos.app.goo.gl/4liEBWosYpzRdEFK2
This is +5 on a dyno, lower frequency and a lower tone, more a burble/fart than a pop:
https://photos.app.goo.gl/w4IYkqxjd7nPwEqC3
Results will vary per exhaust setup. I'm using a catless UEL and a high flow cat in the front pipe, resonated mid pipe and aftermarket (custom) axle back.
Old 04-11-2018, 07:21 PM   #587
elBarto
elBarto's Avatar
Drives: Toyota GT86
V4 A00C
If editing a def file, use notepad++ . It has code-coloring, makes it easier to read and edit.
Make and model doesn't matter, you can put in "Pink unicorn" and it will work.
As said before, only for V4 tunes and remove old definitions in RomRaider or you will brick your ECU.
Old 04-11-2018, 08:22 PM   #588
D_Thissen
D_Thissen's Avatar
Dank je
@bababooey I've noticed the negative values at higher rpms produce a sharp pop. Similar to a gun shot.
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 05:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-18-2014 12:07 AM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
