#589 | |
Drives: frs
#590 | |
Drives: 2014 BRZ - WRB
One other thing I just thought to ask; what initial enrichment are you running? |
#591 |
Drives: BRZ SWP Limited -6MT
yesterday I tried +5 all the way down first column and wasnt satisfied, like mentioned above more tame. so im going back to -6. I found going past single digits (-12) didnt respond quite like i thought it may. but I also think it'll take more than the 20 miles to get the fuel trims dialed in before i really begin to pop again.
#592 | |
#593 | |
#594 |
Drives: 2012 GT86 EU-spec
I did run 1.2 enrichment with the overrun method. I've switched to Ecutek and now run the Base timing method, but with some custom Ecutek tables automatically feathering the throttle on overrun. The result is the same, +5 timing and nice pops. Thus I don't think it matters which method you use, the result of the chosen timing will be the same.
#595 |
Drives: Asphalt 2015 FRS
Want to thank all the contributors in this thread!
Finally got around to trying this out. Only adjusted the 0.15 load range on Ignition B table. Due to the results I read about through this thread, I decided I only wanted modest pops so I wouldn't get tired of it. I put +5 from 2600 to 5400, then above that dropped it to 2.5. I really like how giddy this makes me. If I am trying to do it, they can be a little obnoxious. But what I've really appreciated is the pop on upshifts. I have a track day coming up next month so I am excited to see how this sounds when doing actual performance driving and not just cruising around town.
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
#596 |
I'm running this setup right now: +10 @ 2500, +5 @ 3500, +2.5 @ 4500, 0 @ 5500.
You get some nice burbles below 3500, anything above 4500 is a loud pop. It sounds fine when you're downshifting on the highway, but it's a bit obnoxious around town. I might try +10, +10, +5 and +5 and see if that helps.
#597 |
Drives: 2016 Subaru BRZ Series.Hyperblue
#598 | |
#599 |
Drives: frs
#600 | |
Drives: Toyota GT86
And the "in gear table" has been rescaled. You can change the values above the datacells as well.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#601 | |
Drives: GT86 AT 2013
Pls help
#602 |
Drives: 2013 Subaru BRZ Premium
Got a video?
2000 BMW 323i 2013 Subaru BRZ Premium |
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 05:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 06:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 08:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-18-2014 12:07 AM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 03:12 PM |
