CANADA Canada
Old 04-23-2018, 04:41 PM   #1
interna
Hamilton, Ontario
interna's Avatar
Drives: Scion FRS
FT86 Motorsports Oil Cooler Kit
Anyone own one of these? Any feedback? pros/cons.
Comparing between Mishimoto and FT86MS.
Ft86motorsports is using a RacerX thermostatic sandwich plate which is comparable to Mocal. Both 19 row so cooling surface area is good. I would be under the impression its a decent product.
Only differences I can find are the mounting hardware.
Any info/feedback greatly appreciated.
interna is offline   Reply With Quote
Old 04-24-2018, 04:47 PM   #2
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
Have the Mishimoto, does what it's supposed to do (seeing temps in the 102-105C range at Mosport). We did the installation, just have to be patient with routing the oil line from the cooler to the oil filter. Don't drive the car in the winter so no comment there.
Mike
tanner is offline   Reply With Quote
Old 04-24-2018, 06:04 PM   #3
wparsons
wparsons's Avatar
I've got the Mishimoto thermostatic version, zero issues (no leaks or sweating), and it's winter driven.
flickr
Old 04-25-2018, 11:47 AM   #4
interna
Hamilton, Ontario
interna's Avatar
Drives: Scion FRS
Thanks for the feedback guys. More refinaed answer in this sub especially with our winters here.
@wparsons. Thanks for the winter usability insight.
Thank you.
Old 04-25-2018, 11:57 AM   #5
TRAKRAVN
Drives: 2015 Scion FRS - Raven
I had/have the Mishimoto oil cooler kit. The thermostat plate leaked and pissed all over the engine. I was just lucky it didn't cause a fire. I had the kit professionally installed and the installer came to pick up the car with the trailer. He tried to correct the Mishimoto parts with new gaskets and fittings and it still leaked. I ended up using the Kraftwerks oil filter adapter and the Mishimoto lines and cooler and have not had a problem with it since. Keep in mind my car is only tracked and not street driven. Although the leak happened driving home from the shop after install. It could have just been a bad batch of machining, as others have had no problems with the Mishimoto kit.
TRAKRAVN is offline   Reply With Quote
Old 05-11-2018, 10:24 AM   #6
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Did you reach out to Mishimoto?
bmxr is offline   Reply With Quote
Old 05-11-2018, 11:25 PM   #7
wparsons
wparsons's Avatar
My mishimoto core just sprung a leak, no visible damage to the core but it's definitely leaking from one of the bars. Pulled the kit until I can get a replacement core and still no leaks or sweating from anywhere else!
flickr
Old 05-12-2018, 12:33 AM   #8
tanner
Well that sucks, or is it well that leaks
When I had the car tech'ed last week, the elbows that connect to the filter and to the oil lines, the elbows were a little loose and had that tightened. Oil lines to the elbows themselves were tight.
Mike
Old 05-12-2018, 06:41 PM   #9
TRAKRAVN
No I didn’t bother. I’m figured it’s racing parts and there is no warranty. I also didn’t want to run a thermostat anyway.
After my leak I had read about other people had issues with some core leaks so I bought a back-up Setrab cooler that’s about 125% the size of the mishimoto one. If I get to point that I have to install that I’ll just replace the Mishimoto lines at the same time.
Old 05-12-2018, 10:41 PM   #10
wparsons
wparsons's Avatar
Mishimoto has lifetime warranty on the oil cooler kits...
flickr
Old 05-30-2018, 12:31 PM   #11
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Interna - have you purchased a cooler yet?
If not, www.dsgperformance.com in Montreal is a Mishimoto Dealer and www.ft86motorsports.com have great prices and no funky shipping issues since they in Ontario.
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
Solved: Full Blown Motorsports Oil Cooler Leak (Pics and Video) Sachmet43 Engine, Exhaust, Transmission 27 05-04-2021 01:21 PM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 11:16 PM
P&L Motorsports BRZ / FR-S Engine Oil Cooler Kit - FMIC Compatible P&L Motorsports Engine, Exhaust, Bolt-Ons 62 09-24-2015 05:43 PM
Fs: Full Blown Motorsports oil cooler protpibe Engine, Exhaust, Bolt-Ons 1 03-25-2015 07:36 PM
HKS Oil Cooler Kit - A must for track days - FT86 Club Private Sale $928 delivered!! TAP Auto Parts Engine, Exhaust, Bolt-Ons 5 11-30-2012 11:01 PM
