Old 02-08-2018, 08:13 PM   #1
Gunman
Drives: 2019 Mazda Miata RF
Super bright leds fog light kit
Anyone using these? thoughts?
LED Headlight Kit - PSX24W LED Fanless Headlight Conversion Kit with Compact Heat Sink
Part Number: PSX24W-HLV4
https://www.superbrightleds.com/more.../#tab/Overview
Old 02-11-2018, 05:46 AM   #2
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
I used a night eye brand ..... the problem is with the high beams are mega powerful. Dangerous to turn on at night, did once to test them out and a boy 40m up the road shouted "HAY rever" - just bare in mind that they will scatter in full circle.
For the Low beams lucky I have a electronic switch that allows me to adjust the angle of the direction of the beam as I had to point it lower than before.
Makes driving much more enjoyable and you can see a lot more, just only use the high beams in a emergency or when your own your own
FRS2017 is offline   Reply With Quote
Old 02-11-2018, 12:15 PM   #3
Gunman
These are actually fog light leds, the term "headlight" in this case is inaccurate, so the is no highbeam.
Old 02-14-2018, 07:42 PM   #4
Gunman
OK, here is the Super Bright LED fog light, compared to the 5 year old incandescent.
Old 02-14-2018, 08:49 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Is it brighter? Yes. Can same be answered if it won't dangerously blind oncoming traffic? Or such minor details no-one cares about these days?
Old 02-14-2018, 11:25 PM   #6
Gunman
That point will be checked tomorrow morning.
Old 02-15-2018, 12:43 PM   #7
Gunman
First drive this morning. Fog light beam pattern looks much like oem, but brighter. The ground in front of the car was lit up nicely. With the led's emulating an incandescent, that is what I expected. Now to get some fog, so I can see how they work doing their actual job.
Old 02-15-2018, 12:46 PM   #8
Vital
Drives: 2015 BRZ
Were these plug and play for the BRZ fog light housing?
Old 02-15-2018, 07:37 PM   #9
Gunman
Yes.
Old 05-23-2018, 10:35 PM   #10
Snoopyjh
Drives: 2014 BRZ Limited
Do you still have the stock headlight hids? How does the new fog light color match with the headlight low beam color? Thanks!
Snoopyjh is offline   Reply With Quote
Old 05-24-2018, 12:48 PM   #11
Gunman
Fogs are a touch more to the blue spectrum.
FS: Helix Clear Sides with Bright White LEDs Asphalt~86 Exterior Parts (Aero, Lighting, Etc.) 3 12-04-2013 11:08 PM
Meng Motorsports Super Bright and Reliable LEDs Sale! Low Price! Mengsta Exterior Parts - Lighting 69 08-19-2013 04:52 PM
