Old 10-16-2017, 08:36 PM   #29
Bokusārēsā
Bokusārēsā's Avatar
Drives: 2015 Scion FR-S
You guys deserve an award! Like the Boxars ;-) (Boxers/Oscars). Staying tuned. :-)
Bokusārēsā is offline   Reply With Quote
Old 11-05-2017, 04:46 PM   #30
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
I had some free time last week and tore apart the first transmission that was sent in for the rebuild. Waiting on the other tester to send in his trans and then we are still looking for (1) more guy if you want in on this!
I have a spare, in good shape, transmission on hand now as well, if sourcing a transmission is an issue.
Thank you,
Eric
VerusEric is offline   Reply With Quote
Old 01-08-2018, 12:33 PM   #31
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Old 02-12-2018, 02:29 PM   #32
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Thank you,
Eric
Any new data to share?
SpectreRT is offline   Reply With Quote
Old 02-12-2018, 08:24 PM   #33
VerusEric
VerusEric's Avatar
The transmissions took a bit longer to get in than anticipated but all (3) test units are blown apart and being put back together. Below are some photos.
Getting closer to having some more running the gearset we helped develop, which is exciting!
Thanks,
Eric
Old 03-16-2018, 10:53 PM   #34
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
Any more information on this? Cost? Hows development going etc.
laextreme5 is offline   Reply With Quote
Old 03-18-2018, 08:05 PM   #35
VerusEric
VerusEric's Avatar
Been building them after hours the past few weeks. I believe I should have the remaining (2) units buttoned up by Monday next week, or at least that is the plan. Below are some photos. I was shooting for a price of under $3k for the kit, I'm unsure at this time if we will be there or not.
Output shafts assembled, countershafts started:
Countershafts Fully Assembled:
Countershaft rear tapered roller bearing outer race being installed
Daniel's transmission going together:
Thank you,
Eric
Old 04-29-2018, 10:09 PM   #36
VerusEric
VerusEric's Avatar
We have two more transmissions, running and driving in a car at this point, with the 3rd being installed shortly.
So far nothing really to report.
Sam was gracious enough to do something I have wanted to do for 6+ months. He took a video of the gearset in action so you can hear the noises she makes. 1, 2, 5, and 6 are basically the same as OEM noise level, with 3rd and 4th sounding like a straight-cut gearset should.
Thanks,
Eric
Old 06-12-2018, 05:34 PM   #37
VerusEric
VerusEric's Avatar
Another of our Beta testers has been down the drag strip a handful of times and now pushed his power up higher. These dyno pulls were done in 4th gear as well.
Thanks,
Eric
Old 06-12-2018, 05:47 PM   #38
valtore101
Drives: 2016 FR-S
Thanks,
Eric
I'm guessing this customer has a built short block and stock heads? Excited to see a gearset for this motor that can hold some power.
valtore101 is offline   Reply With Quote
Old 06-13-2018, 09:51 AM   #39
VerusEric
VerusEric's Avatar
I don't know his full build but yes he has a built bottom end. No idea what is done to the heads.
Thanks,
Eric
Old 06-13-2018, 10:58 AM   #40
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Eric, On the video I thought I heard a small chirp on throttle down between shifts. Is that my imagination and if not, what is it?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 06-27-2018, 01:44 PM   #41
VerusEric
VerusEric's Avatar
You'd have to ask Sam. He runs a Motec M150, it does have the capabilities to throttle blip on downshifts. Otherwise, it's making normal noises in the video; sounds exactly like my transmission in my car.
We have a few extra units that have been finalized if anyone is interested. Please PM/e-mail us for any information.
Thanks,
Eric
Old 11-11-2018, 05:19 AM   #42
Ranran
Drives: 2017 86
Any updates? Or an estimate of when the kit will be available?
Ranran is offline   Reply With Quote
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 05:12 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 06:23 AM
Beta Tester needed for E85 tuning in the San Antonio/Austin Area Dynotronics1 Southwest 2 12-31-2012 03:08 PM
