Old 04-27-2016, 12:10 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by ztan View Post
***Use at your own risk.***
This implementation hijacks the speed limiting fuel cut routine and assesses MAP instead of vehicle speed.
Defined for A00G/A01G ROM: a single value in the speed limiting fuel cut routine is changed (from 0x58 to 0x5A) to get MAP loaded instead of speed and MAP limits are entered in place of speed limits. To clarify, no additional patch is needed for this modification besides the single value switch in the code - thanks to Subaru engineers who just lifted the speed limit rather than write new code.
This is really great work man!! You're awesome!
Old 01-06-2018, 07:52 AM   #16
makinen
makinen's Avatar
Drives: Toyota 86
This boost cut mod is working pretty well!
I modified A01E CAL ID rom file for this boost cut mod and got good result.
Boost cut activated at 8 psi and deactivated at 7.5 psi.
https://datazap.me/u/makinenkr/20180...zoom=2728-2758
It might need fine tuning of parameters to prevent boost fluctuation.
Good job @ztan !
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 01-08-2018, 02:42 AM   #17
steve99
Drives: FT86
Attachment 161593
Good job @ztan !
Nice work,
you could likey just use the entire A01G rom in your car and get flexfuel as well
Old 07-06-2018, 03:16 AM   #18
makinen
makinen's Avatar
Drives: Toyota 86
I've applied over boost fuel cut to and tested with Kouki K00G-based OTS ROM. It works as A01E or G.
Old 07-05-2023, 09:30 AM   #19
makinen
makinen's Avatar
Drives: Toyota 86
Modifications for K00G
As @AussieBRZ mentioned this is required for K00G rom, I'd like to add my modifications for K00G. Any rom definitions based on K00G could work.
But as usual use this at your own risk.
Code:
		<!--table name="Speed Limiting Enable (Fuel Cut)" storageaddress="10e924"/-->
		<table name="Boost Limit (Fuel Cut) enable" storageaddress="69D45" />
		<table name="Boost Limit (Fuel Cut)" storageaddress="10E924" />
		<table name="Boost Limit (Fuel Cut) Resume" storageaddress="10E934" />
		<table name="Boost Limit (RPM) Active" storageaddress="10E938" />
		<!--table name="Speed Limiting Disable (Fuel Cut)" storageaddress="10e92c"/-->
This tweak works by toggling "Boost Limit (Fuel Cut) enable" which writes not a value byte but a code byte actually.
Code:
		<table type="Switch" name="Boost Limit (Fuel Cut) enable" category="Miscellaneous - Limits" sizey="1">
		  <description>Enable Boost Limit (Fuel Cut)</description>
		  <state name="Enabled" data="5A" />
		  <state name="Stock ROM" data="58" />
		</table>
		<table type="2D" name="Boost Limit (Fuel Cut)" category="Miscellaneous - Limits" storagetype="float" endian="little" sizey="4" userlevel="4">
		  <scaling units="Manifold Pressure (psi relative sea level)" expression="(x-760)*.01933677" to_byte="(x/.01933677)+760" format="#0.00" fineincrement=".01" coarseincrement=".5" />
		  <table type="Static Y Axis" name="Boost Limit Fuel Cut" sizey="4">
			<data>On Above</data>
			<data>Off Below</data>
		</table>
		  <description>These are the MAP values at which the boost limiter is engaged and disengaged. When engine speed is equal to or exceeds the 'On' value, fuel cut is active, after which, if engine speed drops below the 'Off' value, fueling is resumed.</description>
		</table>
			<table type="2D" name="Boost Limit (Fuel Cut) Resume" category="Miscellaneous - Limits" storagetype="float" endian="little" sizey="1" userlevel="4">
		  <table type="Static Y Axis" name="Boost Limit Fuel Resume (MAP)" sizey="1">
			<data>Below</data>
		  </table>
		  <description>After the boost limiter is engaged and engine speed drops below the 'Off' RPM, fueling will not resume until manifold pressure drops below this table's value.</description>
		</table>
		<table type="2D" name="Boost Limit (RPM) Active" category="Miscellaneous - Limits" storagetype="float" endian="little" sizey="1" userlevel="4">
		  <scaling units="Engine Speed (RPM)" expression="x" to_byte="x" format="#" fineincrement="50" coarseincrement="100" />
		  <table type="Static Y Axis" name="Boost Limit Active over" sizey="1">
			<data>Over</data>
		  </table>
		  <description>The boost limiter is active over this RPM</description>
		</table>
Old 02-15-2026, 02:32 AM   #20
callisto
Drives: 2019 Subaru BRZ
Code:
This is, apparently, completely unchanged all the way to V00C/U01A. And confirms something, since I have a variable there labeled "map_maybe". Thank you for posting this! For those who need it, then, here's the correct addresses for those (the rest of the definitions are unchanged as per above).
U01A:
Code:
		<table name="Boost Limit (Fuel Cut) enable" storageaddress="6A9E9" />
		<table name="Boost Limit (Fuel Cut)" storageaddress="10E604" />
		<table name="Boost Limit (Fuel Cut) Resume" storageaddress="10E614" />
		<table name="Boost Limit (RPM) Active" storageaddress="10E618" />
V00C:
Code:
		<table name="Boost Limit (Fuel Cut) enable" storageaddress="71579" />
		<table name="Boost Limit (Fuel Cut)" storageaddress="11207C" />
		<table name="Boost Limit (Fuel Cut) Resume" storageaddress="11208C" />
		<table name="Boost Limit (RPM) Active" storageaddress="112090" />
The exact bytes surrounding the 'enable' location are unchanged from A01C..V00C, so:
4c f0 ff cb ff eb ff fb d2 <Enable>58 fe 28 d2 58 fc 28 d2 58 ff 28 d2 58 42 4b d2 58 42 0b 6c 0c
Searching for those hex bytes in the file appears to return a single location in any BRZ gen1 ECU, and that first '58' in the command 'd2 58' is what the 'enable' entry modifies above. Similarly, this locates the other three addresses:
44 7a 00 00 44 7a 80 00 <Fuel Cut>43 fa 00 00 43 fa 00 00 43 f5 00 00 43 f5 00 00 <Resume>44 7a 00 00 <Active>45 89 80 00
(If you are not familiar with hex editing and can't recover from a bricked ECU, you probably shouldn't try to use this information, but if you understand what you're doing, this is perhaps hours to weeks of time saved. Cheers.)
callisto is offline   Reply With Quote
Open source Hybrid Speed Density ztan Software Tuning 57 07-05-2023 09:33 AM
Open Source Electric Supercharger neutron256 Forced Induction 913 08-22-2021 06:16 PM
open source software question GeeTee86 AFRICA 15 02-15-2015 07:52 PM
The Retrofit Source summer open house! soundman98 Southeast 0 06-23-2014 09:41 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 04:33 PM
