Old 08-17-2018, 05:48 PM   #43
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by freerunner View Post
I don't do it because I drive my car in the summer and in the winter.
The UK got neither. Only rain. *cough*
that doesnt make sense. there are other compensations applied against temperature and pressure and if you disable ltft in open loop and scale well the maf, you get a matched afr in summer and in winter and with storm and with hot sun
with ltft enabled? you get random afr every f*cking day : )
Old 08-17-2018, 05:50 PM   #44
vtekdis
Drives: 2013 BRZ Premium
Originally Posted by tomm.brz View Post
just disable ltft in open loop and you dont have to care about ltft in 3v area
just scale the maf in open loop and you will always have a perfect afr for a given fuel,without worrying of ltft applied
For me it's purely educational since I want to get deeper into ECU calibration. I understand that there are other methods.
vtekdis is offline   Reply With Quote
Old 08-17-2018, 05:55 PM   #45
freerunner
freerunner's Avatar
Drives: GT86
Originally Posted by vtekdis View Post
Based on your spreadsheet and the data you used what's the point of all of this if your calculated MAF points below 3V are exactly the same as the VGI generated scale? Am I missing something?
Control. If the final fuel-trim is thrown off, all it takes is to adjust one CAL-value left and right of the 3V cell to bring it back in line.
That's one out of many possible ways to do it.
Wait. You mean the ECU still compensates for ambience temperature?
freerunner is offline   Reply With Quote
Old 08-17-2018, 05:58 PM   #46
tomm.brz
ltft works very good.. for different fuels use and for tunes that need to work off-the-shelf for a large amount of similar cars
if you spent time and resources in scaling the maf the best you can, ltft in open loop become useless to my point of view, just disable it and scale well the maf and afr will always be matched with the target afr
Old 08-17-2018, 06:09 PM   #47
freerunner
freerunner's Avatar
Drives: GT86
Well always thought that the ecu stops compensating for oxygen density as well. Again something learned, thank you! I think I'll give it a try next weekend.
Old 08-17-2018, 08:35 PM   #48
tomm.brz
can t remember in romraider how it s called, but in ecutek look for the map "airtemp vs airflow compensation"
that s enough to compensate for IAT variations during open loop
in closed loop stft and ltft still work
Old 08-20-2018, 02:18 AM   #49
freerunner
freerunner's Avatar
Drives: GT86
Flashed and went for a drive last weekend. Disabling LTFT in OL was one of the best things to do.
Now the next thing to do is installing the wideband sensor, which is lying on my desk for about 2 weeks now.
Old 08-20-2018, 10:53 AM   #50
vtekdis
What's the name of the table?
Sent from my SM-G955U1 using Tapatalk
Old 08-20-2018, 12:35 PM   #51
freerunner
freerunner's Avatar
Drives: GT86
For Brzedit, it's Long fuel trim maximum A&B + Long fuel trim minimum A&B
For Romraider I'm just guessing: AF learning #1 limits
Probably a bad idea to zero these tables out on a non-flex-fuel ethanol tune.
Old 08-20-2018, 01:38 PM   #52
tomm.brz
right, you should disable ltft in open loop only if you scape perfectly the maf and use always petrol E0
equal length, header, romraider
FS: Innovate I/C supercharger and Nameless header and option of install and tune Lawnik Canada Classifieds 15 01-26-2015 12:01 PM
stg1 custom tune add intake retune =??? StormTrooper Engine, Exhaust, Transmission 11 12-23-2013 06:59 PM
AVO STG1 Turbo Kit New in the Box w/Visconti map sensor upgrade and tune JMPoole Engine, Exhaust, Bolt-Ons 8 04-04-2013 05:47 PM
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 04:56 PM
Perrin STG1 tune Celica00 Engine, Exhaust, Transmission 125 10-20-2012 12:59 AM
