Old 08-21-2018, 09:28 PM   #17053
spike021
spike021's Avatar
Originally Posted by Chikna View Post
I have a question on releasing clutches. I release slowly for 2nd and 3rd, bit faster for 4, 5, and 6. However, I always bring clutch to biting point for all gears with little gas and release completely. Am I doing right? Some guys told me that 4, 5, and 6, I don't have to hold at biting point just release it fast (not dumping). Thanks.
Like NC said, you don't really need the bite point beyond just getting moving in 1st.
You just want to have smooth inputs on both the clutch and the gas to keep the shifts smooth. Usually that means doing the shift quickly so that the revs don't drop too much.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 08-23-2018, 09:18 PM   #17054
spike021
spike021's Avatar
Originally Posted by BA9092 View Post
Loving the new leather/perforated leather steering wheel from REAL Japan!
Thanks to 86WORX for carrying these - @Max @ 86WORX
Amazing quality, looks great, feels awesome!
After a few days, how does it feel now? Is it grippier/not as slippery compared to the original stock 2017+ steering wheel?
Old 08-23-2018, 09:26 PM   #17055
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Do it! I'll help ya install it
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 08-23-2018, 09:59 PM   #17056
Brink
Drives: 2017 BRZ
Vacuumed and washed my BRZ today. Had a nice little pile of dirt collected under the weathertech floor mats, in the corner below the dead pedal.
Brink is offline   Reply With Quote
Old 08-23-2018, 11:13 PM   #17057
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
Still looks and feels like it did on the first day. The leather seems to be of higher quality than OEM, that's for sure.
BA9092 is offline   Reply With Quote
Old 08-24-2018, 01:19 AM   #17058
Chikna
Drives: 2018 BRZ TS 244/500
After depressing clutch all the way to the floor, when I change gears either 2nd or 3rd I hear some sound under the stick is this normal? It's not grinding right?
I have 900 miles now after driving 3 weeks. I am not good in smooth shifting and there is slight jerk and sometimes slight noise while shifting. I haven't noticed grinding noise so far. I am frustrated that I haven't driven cleanly so far. There was a fear of slow start from stop and that is gone. Yesterday, WRX was driving behind me and later he came next to me and waved at me kind of good?
Chikna is offline   Reply With Quote
Old 08-24-2018, 06:41 PM   #17059
dreroc-z
Drives: 1989 Camaro IROC Z28
Planned to install my Swift springs, White Line camber bolts and White Line RLCAs today. Stripped out the end link...of course. Have a new set in the mail so I’ll have to reschedule all the work until next week. Should have just planned to replace them anyway and just cut the old ones out. Feeling disappointed but once all that’s done I’ll have my xxr 527s ready!!
dreroc-z is offline   Reply With Quote
Old 08-24-2018, 07:24 PM   #17060
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
How are we supposed to know if the sound is grinding or not when we haven’t heard it? If you are pushing the clutch pedal all the way to the floor before shifting as you mentioned above, it probably isn’t grinding. Again... it’s more about synchronizing your clutch/throttle inputs than how long you hold the clutch pedal down. Typically a “jerk” after shifting as you have described is due to releasing the clutch without applying any throttle to synchronize the shift. Just remember, shifting smoothly involves using BOTH the clutch and gas pedals, you should be applying some level of throttle before the clutch pedal has been completely released. Try watching some videos or ask an experienced manual driver that you know to instruct you.
NCtoBRZ is offline   Reply With Quote
Old 08-24-2018, 10:25 PM   #17061
JMon85
JMon85's Avatar
Drives: 2019 WRX
Hit 50k mi =)
JMon85 is offline   Reply With Quote
Old 08-26-2018, 09:32 PM   #17062
Chuckls
Moutain Runner
Autocrossed it!
Chuckls is offline   Reply With Quote
Old 08-26-2018, 10:40 PM   #17063
wild03
Drives: Silver 2017 Limited with PP
Originally Posted by Chuckls View Post
Autocrossed it!
Nice! I like the yellow and blue tape to reduce drag and increase HP
wild03 is offline   Reply With Quote
Old 08-26-2018, 10:41 PM   #17064
wild03
I made my own armrest to replace the factory armrest/manual that came in the glovebox.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Used a pre-stitched cover from ebay, from a wrx or something. then used recycled leather for the bottom. wood for the base, and mix of high density and low density foam, first time doing this sort of thing, it was fun and a learning experience.
Old 08-27-2018, 10:24 AM   #17065
Vten
Drives: Too heavy
Did a DIY alcantara steering wheel cover, not bad for the price !
Vten is offline   Reply With Quote
Old 08-27-2018, 10:49 AM   #17066
speed-wiz
speed-wiz's Avatar
Drives: MR2
Nice job!
speed-wiz is offline   Reply With Quote
