Old 01-01-2017, 10:07 PM   #141
gramicci101
Off Topic
@switchlanez and several other people run them. The smallest that would fit is probably 16x7. They're very expensive. Mach V sells a 17x9 for $700 ea. They're on my list of wheels I want, but that is a lot of money.
Old 09-05-2017, 07:47 AM   #142
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Originally Posted by coyote View Post
Please don't post those pictures, or I may buy a second set for the track.
or a fourth....
86•BRZ is offline   Reply With Quote
Old 09-11-2018, 12:54 PM   #143
funwheeldrive
I'm bumping an older thread so I don't have to make a new one.
I'm looking at a set of these wheels 16x7 in size. If I buy these new I'm guessing I will need to switch over my TPMS sensors? Is that something a wheel shop can easily do while swapping in my new wheels? Also, does anyone know what type of lug nuts I would need?
It's surprising I can't find many pictures of our cars with the 16 inch version of this wheel. The only place I can find pictures is off of Japanese websites. Does anyone on here have these wheels in 16x7????
Old 09-11-2018, 01:02 PM   #144
Vital
Drives: 2015 BRZ
Yes, you will need to swap over your TPMS sensors from your OEM wheels to the new ones. Any wheel and tire shop should be able to do it.
As for lugnuts you will need aftermarket tuner lugs. They are 60 degree taper conical shaped.
Old 09-11-2018, 01:09 PM   #145
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
The OEM lug nuts are already 60* tapered
@funwheeldrive You only need aftermarket lug nuts if you want a different style/color
BigTuna is offline   Reply With Quote
Old 09-11-2018, 01:39 PM   #146
funwheeldrive
Awesome thanks, I'm not picky about lugnuts and I really didn't want to spend more money considering how expensive just the wheels are.
Old 09-13-2018, 03:48 AM   #147
MrDinkleman
Drives: 2016 Oceanic, "base" model
http://www.ft86club.com/forums/showthread.php?t=27023
Heres a thread of 16inch wheels. Specifically, post #485 has a pic of TWS. His first picture post is #214. There are more pics of 16" wheels as well. I have Enkei RPF1 in 16"
MrDinkleman is offline   Reply With Quote
Old 09-13-2018, 11:57 AM   #148
funwheeldrive
Thanks for that. I follow that thread pretty close because I've wanted 16'' wheels for a while. I was hoping to find a picture of the gunmetal grey TWS wheels on a twin, but have only found that gold color and the brushed metal so far.
Old 09-13-2018, 04:57 PM   #149
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Thanks I have been looking for more pics of the 16" setup
Whats holding me back is I don't like the Offset is the same as stock. Meaning you will have $2500 wheels that would still need spacers to sit close to flush. If they came in 16x7 at a +30 offset even if it weighed 2lbs more that would be much better. My 20mm spacers weigh 2lbs so that's where I got the number.
16x7 +30 offset 12.5lbs would make them worth it
Otherwise 16x7 +35 13.7lbs RPF1's more than half the price isn't a bad compromise and wouldn't look bad without spacers
SuperTom is offline   Reply With Quote
Old 04-27-2021, 06:39 PM   #150
saltywetman
Drives: 2020 Toyota 86 GT 6M
Mine came in today! Limited edition color gloss pearl gold in 18x8.5
saltywetman is offline   Reply With Quote
Old 04-28-2021, 02:25 AM   #151
WC-BRZ
Drives: Black BRZ
Beautiful! How much do they actually weigh? I know CSG has the weights listed on their site but would be nice to verify
WC-BRZ is offline   Reply With Quote
Old 04-28-2021, 06:25 PM   #152
saltywetman
Will be bringing a wheel to a buddy's shop in a bit (forum member CrazyWookiee) to do a video review of the wheel on his youtube channel so he'll weigh everything and I'll link the vid onto here after
Old 04-29-2021, 02:58 AM   #153
saltywetman
Got back from the video review shoot. On his digital scale it weighed in at 16lbs flat. Official specs is 6.97kg/15.4lbs for 18x8.5
https://www.tws-forged.com/tws_t66-f.html has the weights for every size/bolt pattern/offset as well
Old 08-01-2021, 08:12 PM   #154
saltywetman
quick bump, @CrazyWookiee posted the video review up on his channel earlier today
Wheels similar to Technic mesh wheels on bmw's DYOLF26 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 04-26-2017 11:29 AM
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 10:26 AM
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 09:46 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 11:26 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 11:08 PM
