#15 | |
Drives: Subaru BRZ 2013 Limited Manual
#16 | |
Senior gif poster
Drives: 2013 Asphalt FRS
Im not familiar with that issue, just did a bit of research. Strange mine has been fine and never had an issue. Does this only happen at the track? Last edited by DandoX; 04-01-2019 at 08:21 PM. |
#17 |
I've never tracked my cars. It starts with issues starting the car where it'll start and then die. If it does happen to you at some point, make sure they put on a new wiring harness and not just the same old design coils, or it'll happen again.
#18 | |
![]() humfrz |
#19 |
Senior gif poster
#20 |
#21 | |
Senior gif poster
I think we may have 'tuesday cars' as it has been put by @TheRacersLine |
#22 |
The coil pack problem is mostly related to heat. If it you’re up north and never track the car then you are probably fine.
As for 50k being in the clear. Mine was at 83k miles when #3 went and the other three had brass coming through so they wouldn’t have been far behind. I think the previous owner just didn’t drive the car hard enough to have oil pressure issues. It probably never saw redline before I owned it. Under my ownership it sees redline a hand full of times a day. I also autox it. I suspect that if I owned the car from day one it would have gone much sooner. There were no signs of bolts being removed anywhere on the car and no other evidence of mods. The CD player came with a B52s CD in it if that tells you anything. Hahaha Before anyone calls my driving abuse, I’ve run previous cars much harder than my FRS and didn’t have bearing failures. My old Integra GR-R was autoxed every month for about 4 years and saw redline anytime the roads were open. The only real issues I hard were syncros and pressure plates flying apart because I regularly flat shifted. I was young and drove like a retard. I did end up hydrolocking it in a flood and after that it was down hill with a spun bearing a year later year then 6 months later and then 2 months later. It also started burning oil due to the water damage to the cylinder walls which were still there even after boring to the service limit and running oversized pistons. |
| 2016 OEM Head Unit in a 2014 | AnotherSlowAE86 | Electronics | Audio | NAV | Infotainment | 0 | 08-14-2018 08:13 PM |
| WTB: 2014-2016 BRZ CWP (SoCal) | icecord | Want-To-Buy Requests | 2 | 06-30-2016 07:09 PM |
| WTB 2014-2016 SWP BRZ Limited - SoCal | icecord | Want-To-Buy Requests | 5 | 06-07-2016 04:39 PM |
| 2016 FR-S vs 2014 WRX Hatchback | SosaR | FR-S / BRZ vs.... | 47 | 05-05-2016 02:53 PM |
| Do the 2013 and 2014 FRS models have the same engines? | Turbo_FRS | Scion FR-S / Toyota 86 GT86 General Forum | 83 | 12-16-2013 12:36 AM |
