Old 10-16-2019, 01:44 AM   #1
Inazuma in NS
Inazuma in NS's Avatar
Drives: 2017 BRZ Inazuma
Header advice - 2017
Hi all,
New owner of a Canadian 2017 Inazuma or Yellow edition. Bought with 10,000 kms and in immaculate condition. Previous owner put quite a few mods into it listed below.
OEM+ Ref 450q
Borla Cat Back exhaust
Eibach pro-plus Suspension springs and Front / Rear sway bars (car is lowered)
Perrin Rear shifter Bushing
Perrin Transmission mount support
Grimmspeed Cold air intake
HKS intake scoop
AEM Front Strut bar
Grimmspeed Gas Hood struts
many more cosmetic add-ons I won't list.
I'm a complete novice when it comes to tuning or modifying so I went for an "easy' gain and purchased an OpenFlash Tablet V2 and managed to install a stage 1 tune. I did notice a difference but now as I research more I'm thinking I'm going to change out the header for a greater gain.
These forums are amazing to read and I think I've settled on the Ace A-350 with a Ceramic coatings from CounterSpace....here comes the advice part.
Best gas I have here is 91 Octane and I'm not sure if there are any really good tuning shops in Halifax N.S.
Is it possible to install the A-350 and have a tune done with the OFT and makes some respectable gains or would I be wasting my time. I see that most go with a Delicious tune and that seems like a completely different system. As I stated I'm novice and the OFT was easy for my skill level, I'm not interested in taking my car to the track but I do drive a lot faster that I should and want to remove that dip.
I know if I'm investing in the new header I should have it professionally tuned however as stated I don't think there is a quality tuner garage locally ( or one that's been given good feedback from what I've heard ).
Thoughts? and that you in advance for all the comments and the forums you've created here.
Inazuma in NS is offline   Reply With Quote
Old 10-16-2019, 02:41 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
AFAIK it's possible to get something via OFT, eg. trying long tube header avcs tables and work from there, but usually people choosing/buying ace headers have clear goal of getting best, and for best gains with them one should go with DT ecutek tune. Ace headers showed little gains with generic OTS tunes, Delicious spent LOT of dyno time of getting tune right on those. So i'd probably unmarry OFT from car, sell it in classifieds, and install DT tune. Of course, it's also possible to have it locally tuned, but i'm certain that nor you nor hypothetical local professional tuner be able to invest that much time/money as DT did for getting tune right, even if tuner is competent enough, so it looks to me as spending more to get less. Better go proven route.
Old 10-16-2019, 03:21 AM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
You should message @Wayno he has tuned a lot with OFT, his own ACE header as well. His tunes are better than what you'll get from OFTs own site.
PulsarBeeerz is offline   Reply With Quote
Old 10-17-2019, 11:34 AM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by Inazuma in NS View Post
Hi all,
OEM+ Ref 450q
HKS intake scoop
AEM Front Strut bar
If you're set on the ACE header, I'd say save up a bit and get ECUTek and tune it that way. It seems intimidating but there are some great videos talking you through it.
MS, CSCS, TSAC-F, CPT
Old 10-17-2019, 11:43 AM   #5
86TOYO2k17
Drives: 2017 toyota 86
assuming you have a laptop, then ecutek is really no different or more complicated then a OFT. Download ecutek software, plug in dongle and then OBDII cable to car, download tune from tuner, upload into ECU. pretty easy and straightforward.
I initially used OFT OTS tune with ACE header and noticed almost zero gains, then i got a custom tune and it was a night and day difference not even the same car anymore. in hind sight i would have gone ecutek from the get go. My custom OFT tune was perfectly fine but it took 6 months to finish. and i ended up going FI and switching to ecutek anyways.
Old 10-17-2019, 12:38 PM   #6
Lantanafrs2
Drives: 2013 frs red
I think a good tuner would prefer the stock airbox. After that, ace header with tune from csg will be the best and most expensive. I use oft and generic header but I'm using e85 so it really doesn't matter.
Lantanafrs2 is offline   Reply With Quote
Old 10-17-2019, 01:47 PM   #7
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
You are better off with a stock header and good tune than a good header and shit tune. I would do the tune from CSG(Zack) then header if finances allow.
Old 10-17-2019, 01:58 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That's interesting. Initially when I got my OFT my car was worse with an OTS tune(stupid Perrin CAI). Once I got the Maf scaled properly it was an improvement. Sticking a header, Nameless, also was quite a noticeable improvement with no change to the base tune. It did, like you, take a season of fine tuning to get it to a spot where it is pretty good.
Old 10-17-2019, 02:14 PM   #9
86TOYO2k17
OFT OTS tunes work fairly well with most header designs. Can still be optimized for specific setups but not necessary unless you need MAF scaling. However the ACE header in particular is just too different of a design to work well and benefit from a OFT OTS tune. So it needs a custom tune.
Old 10-17-2019, 02:29 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I understand that. I just find it odd as I did notice a difference with the Nameless which requires quite a bit of change to the avcs table to get the most out of. I just find that interesting.
Old 10-17-2019, 06:10 PM   #11
PulsarBeeerz
There are already ACE specific OFT tunes available for the ACE header from 3rd party tuners. Wayno has delt with them and most likely Steve99 has as well. Cam settings for the Nameless header are even readily available with a forum search.
Old 10-17-2019, 09:00 PM   #12
86TOYO2k17
They offer free OTS OFT ACE tunes? Or they are able to provide custom oft tunes for the ace? Because i was not aware of the former.
Old 10-17-2019, 09:28 PM   #13
PulsarBeeerz
They aren't free, gotta pay for their time but, atleast one of them has tunes available for well below $100. Even has variations of the tune with different MAF calibrations to dial in the A/F raito.
Old 10-19-2019, 09:02 PM   #14
Inazuma in NS
Sorry, was busy last couple days... thanks for all the responses. I didn't realize the ECUtek was as straight forward as the OFT. If it's something I can do without a tuning garage and Dyno I might try that. That leaves a DT or CSG to buy a tune from.
The Ace seems like the header for me based on the reviews and feedback. I'm going to winter my car very soon so I can research all my options.
I still have my stock Air intake and scoop in a box, are the Grimmspeed and HKS that bad or screws up the tune I assume?
3 options for header (looking for advice) gpvecchi Engine, Exhaust, Transmission 16 04-07-2019 01:42 PM
2017 BRZ owners birthday gift advice needed JacobFT BRZ First-Gen (2012+) — General Topics 17 10-26-2017 10:49 PM
Spoiler advice for 2017 86 Sean_IRL Cosmetic Modification (Interior/Exterior/Lighting) 23 04-04-2017 12:32 AM
Need advice on header and overpipe bryansuriel3 Engine, Exhaust, Transmission 11 09-11-2016 03:12 PM
Header and exhaust advice Zan Engine, Exhaust, Transmission 15 09-16-2015 12:07 PM
