Old 10-31-2019, 09:10 PM   #43
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
Originally Posted by UT_BRZ View Post
I run the maestro rr on my 17 BRZ and the five gauges I run are speedometer, coolant temp, oil temp AFR and Boost. I am custom tuned running a JDL turbo setup. Two months ago I flashed my maestro rr to a 17 BRZ and with that update, it enabled TPMS.
Where are you pulling the info for the Maestro rr (obd, etc.)? I have mine wired to the CAN plug behind the glove box to pull all my info.
How did you wire into that CAN plug?
I just received a Kenwood DMX906S and Maestro Rr kit. I thought I saw an image that marked which pin was CAN but now I can't find that image.
I'm really hoping they improved this install because reading through all these troubles has me worried.
RotARy15 is offline   Reply With Quote
Old 11-01-2019, 04:38 PM   #44
COBlue
COBlue's Avatar
Drives: 2017 Subaru BRZ Limited PP
This post has details on the available CAN plug: http://www.ft86club.com/forums/showp...4&postcount=18
Installation is much easier now with SU2 harness and updated firmware.
COBlue is offline   Reply With Quote
Old 11-03-2019, 09:05 PM   #45
RotARy15
Thank you very much. I have gotten the install mostly complete. I was sent an ACC-USB2 instead of the ACC-USB-SU2 that my car needs in order to connect the factory USB and AUX ports to the new radio so the install is sorta incomplete.
It isn't much of a problem as I am still waiting for the Metra harness that I need to connect to the 6 pin in the dash. I have plugged the OBD2 in for the time being to confirm that I am receiving CAN data and that is working great!
I love having tire pressures but what I am really puzzled by is that I am also receiving tire temperature. Does anyone know if this is direct temperature from a dedicated sensor or if this number is somehow inferred from a mix of variables?
Old 11-04-2019, 11:40 AM   #46
RotARy15
Also, holy crap these factory speakers are hot garbage. They should have just deleted the rears and put both those dollars into the doors...
Old 11-04-2019, 01:18 PM   #47
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Yes they are garbage!!!
Drifter X is offline   Reply With Quote
Old 11-06-2019, 09:51 PM   #48
RotARy15
https://pinoutguide.com/CarElectroni...shtml#obd2_iso
According to the link above, the Maestro OBD2 harness connects to the CAN High, CAN Low, and something called the K-Line.
Does anyone have any idea what the K-Line is used for or rather, what data is gathered from it?
Old 11-09-2019, 02:09 PM   #49
COBlue
COBlue's Avatar
Maestro said they're not taking any data from the K-line. I'm connected to just the hi/lo on the CAN and still getting data (although I may have lost tire temp, but as you noted I'm not sure where that's coming from, would have to be TPMS...?)
Old 11-10-2019, 04:36 PM   #50
RotARy15
So I finally finished the install, I got that Metra harness with the 6 pin connector for the factory connector in the dash.
I pulled the pins out of the OBD2 connector and just plugged them into the correct locations on the 6 pin connector. I plugged the K-Line into the 1 empty/blank pin (pin 6) just so it wouldn't short on anything.
Seems I am still getting all the data I used to get. Tire pressure and temp are still working as well as all the throttle position, rpm, water/oil temps. Haven't noticed any loss of functionality.
I do see that some TPMS sensors can gather and send temperature as well. I had my doubts simply because the goal of this car was to be cheap and I didn't expect them to use "more than required" on something such as the TPMS system which is no more than a regulatory requirement.
I'm more than happy with the install. It went pretty smoothly and the only thing left to do is ditch this absolute trash set of speakers and amp. I really hate to add weight to this car so I'm going to try desperately to avoid the addition of a sub. Hopefully I will be satisfied with a 6.5 sub in the doors.
Old 01-28-2020, 12:01 AM   #51
sachu
Drives: rocketship
So I just tried installing the maestro -RR with the SU2 replacing the stock headunit with a pioneer 1440NEX.
I wasn't able to finish up the amp trigger signal so i had unplugged the headunit over the weekend while i was away.
I went back tonight to finish up the wiring and noticed my car battery was completely drained.
I thought the issue was fixed with the new harness.
Any ideas on what am missing or did wrongly?
Going to have to pull the battery (its a shorai with a custom mount that blocks the charge port when mounted) to charge it up before i can give this a go again. sigh.
sachu is offline   Reply With Quote
Old 01-28-2020, 09:48 PM   #52
Drifter X
Drifter X's Avatar
I was able to relocate the mirror backup display to my pioneer head unit!! Brian at www.autoharnesshouse.com hooked me up with a custom harness for my MY19!
Old 01-29-2020, 04:42 PM   #53
COBlue
COBlue's Avatar
I haven't tracked batt volts lately but I've left the car sitting for a few days with no issues. Check my posts #1 and #14 on the first page of thread for my wiring (because my brain can't remember at this point...)
Old 03-06-2020, 09:48 AM   #54
hunsra
@Drifter X can you share a model number or other information on the harness you got from autoharnesshouse? I'd like to get one for my 19 TRD as well. I hate the backup camera display in the rear view mirror and would prefer it to appear in my aftermarket head unit.
hunsra is offline   Reply With Quote
Old 07-02-2020, 05:35 PM   #55
Frankz54
Drives: 2019 Toyota GT86
Yeah i would also like the model number or something for this. I have the 19 as well and hate the small camera in the rear mirror.
Frankz54 is offline   Reply With Quote
Old 07-03-2020, 01:33 AM   #56
Drifter X
Drifter X's Avatar
Hello everyone! Email Brian: inquiry@autoharnesshouse
And let him know you need a custom harness for the 86 or Brz with the mirror camera. He’ll know what you’re talking about.
Installing Pioneer HU and Maestro RR NCtoBRZ Electronics | Audio | NAV | Infotainment 56 05-20-2019 09:16 AM
AVIC-8201NEX without iDatalink Maestro? sgh Electronics | Audio | NAV | Infotainment 7 04-19-2018 02:42 PM
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 09:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 09:59 AM
Maestro idatalink test dummy tofurun Electronics | Audio | NAV | Infotainment 30 10-18-2016 02:01 PM
