Old 11-05-2019, 06:29 PM   #4915
i8ur911
Drives: 17 BRZ Series.Yellow
Originally Posted by TommyW View Post
Did you have to eliminate the windshield washer reservoir with that kit?
Not that I know of, no
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 11-05-2019, 06:32 PM   #4916
TommyW
TommyW's Avatar
Drives: '13 Whiteout
ok great. The Verus site said yes but that seemed odd
TommyW is offline   Reply With Quote
Old 11-05-2019, 06:39 PM   #4917
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Originally Posted by peaches View Post
I've had lower lap times on a 235/45/17 vs a 245/40/17 on 17x9 wheels, same track (PBIR) 2 months apart. My laptop crashed and I lost all my data so I can't help you there.
A proper analysis to determine if a 10mm wider tire will significantly lower lap times is doable but complex and requires lots of data management and reference points. You also have to optimize tire temps and alignment to truly know the benefit of the extra width. I'd be a fun experiment if you can afford it.
Track temps alone could be the difference here. Not to mention driver consistency and other obvious variables.
mistople is offline   Reply With Quote
Old 11-05-2019, 06:47 PM   #4918
i8ur911
I'm incorrect. 100% on me. It does need to be "eliminated", but could likely be relocated with a little work.
Old 11-05-2019, 06:52 PM   #4919
peaches
Drives: '14 BRZ Limited
Either removed, relocated or replaced. I had a reservoir from PTuning, sold it when I installed the supercharger (I removed the cooling ducts and installed a BBK).
peaches is offline   Reply With Quote
Old 11-06-2019, 03:31 AM   #4920
CSG Mike
CSG Mike's Avatar
Originally Posted by Takumi788 View Post
I am in the market of a new set of wheels so I have been thinking about switching from 255/40/17 to 265/35/18 for the increased contact patch on my track only FRS.
Is the extra weight (23 lbs more total), extra height (+.3" dia.) & cost ($389 more per set of tires) worth the extra 10 mm of tire when considering ultimate grip and lap times?
It depends on the track, as well as your car. At the minimum, you'll gain steering response and heat capacity.
Old 11-06-2019, 03:32 AM   #4921
CSG Mike
CSG Mike's Avatar
OK good to know. My fronts just get so damn hot on track days. Smoking if I dont do some cool down time
You should always cool down. Use temp paint on rotors and temp strips on calipers to track peak heat.
You can also run pads that inherently run cooler.
Avoid ABS use if possible.
Old 11-06-2019, 03:46 AM   #4922
CSG Mike
CSG Mike's Avatar
Now this this the type of discussion I was hoping to open up.
Did you record speed via GPS or Wheel speed?
255/40/17 are a lot cheaper than 265/35/18 so I would like to keep using them but the question has me curious.
The 17x10 idea is interesting too.
Two laps for you. For this purpose, compare corner exit speed, vs speed at end of straight.
My video is a 100% stock engine with 18x9.5 TE37Saga with 255/35/18.
Sonny's video is on Ace/E85, with 255/40/17 on 17x9.
For example
Phil Hill apex speed
Me: 78
Sonny: 74
Vmax before Sweeper (corner after straight post phil hill)
Me: 101
Sonny: 106
Sweeper exit apex speed:
Me: 70
Sonny: 66
Vmax before Sunset (esses after sweeper are WOT, then straight to Sunset)
Me: 106
Sonny: 113
Sunset apex speed:
Me: 67
Sonny: 62
Vmax before Sunrise (sunset -> front straight -> Sunrise)
Me: 102
Sonny: 109
Obviously part of this vmax difference is the power and weight difference of the cars, but it does partially illustrate cornering speed gains vs straightline speed gains. Sonny's overall lap is 1.2 seconds faster.
[ame]https://www.youtube.com/watch?v=ax09vTphw3c[/ame]
[ame]https://www.youtube.com/watch?v=-zgIvxVT4ok[/ame]
Old 11-06-2019, 10:23 AM   #4923
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Thanks for the comparo. Super interesting stuff.
I'd also like to add that Apex has confirmed they are working on a 17x9.5 set in GT86/BRZ specific fitment to add to the confusion of wheel choices Maybe this will bridge the gap between the 17's and 18's.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 11-06-2019, 11:02 AM   #4924
Icecreamtruk
Drives: Track preped NA FRS
Yes, im waiting on this for now since I broke two of my wheels I'd rather get a wider 17" set and compare back to back with that as well.
@Takumi788 Speed was measured by GPS on a datalogger (cant trust speedo with different diameters).
Icecreamtruk is offline   Reply With Quote
Old 11-06-2019, 11:19 AM   #4925
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Had to make sure it was GPS based. Thanks! Your data gives me a good starting point.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 11-06-2019, 11:19 AM   #4926
TommyW
TommyW's Avatar
I’m blown away on how many people just come back to the paddock and park it.
what is your favorite streetable track pad?
Old 11-06-2019, 11:25 AM   #4927
Takumi788
JHerbert Racing
Takumi788's Avatar
Hmm. What size tire would you run on this wheel? I have found the widest extreme performance tire (200 tw) is usually at 255/40/17. I suppose there is always r-comps and race slicks but a slight stretch to the 255/40/17 with the extra .5" wheel comparison will be interesting.
Old 11-06-2019, 11:28 AM   #4928
Pat
Pat's Avatar
Drives: 2023 BRZ
How did you break your wheels?
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
