Drives: TRD R.S. 1.0 FRS
Shifter kinda stuck and extr play after clutch install
Hey guys,
i recently did a clutch install(clutch,pressure plate, TOB, verus forged clutch fork and pivot) and the shifter is kinda sloppy, has alot of play. in neutral and in gear. In neutral before the install i would move the shifter left and right and it would snap in center without any slop. Now it slops when i move it left and right. in gear theres about 1-2 inch of play in the higher gears. but most of the gears before the install there not absolutely no play. What would be the cause of this? Im assuming some bushing but i would like to know which one. Diagram of shifter just in case someone can point out what is the cause of this. https://parts.subaru.com/images/part...0_35001284.png i think its the dust boot i torn off the shifter linkage area. https://parts.subaru.com/p/Subaru_20...5016CA020.html its only about $15 so i figure why not pick up. also with my 4th gear. Before the install, car on and without engaging the clutch, trying to shift to 4th gear it would move half inch back towards the gear but not fully go into gear, the shifter would snap right back into the center. now i try doing the same thing, it just stays there now it doesnt snap into the center, i would have to move it myself to the center. UPDATE: i put back the bushing but i screwed up something else. Car wont go into 2nd at all. Last edited by airrick; 04-28-2020 at 03:46 AM. Reason: extra |
#2 |
Drives: FRS
It’s not. I had the same thing. Take off everything so you can see the boot. My bet is it’s the 2 pins and that you didn’t bend the thin bent retention bracket correctly so it’s not holding the top part in correctly
#3 |
Drives: FRS
![]() Sent from my iPhone using Tapatalk |
#4 | ||
Wheels for Brains
Those are about the only things I think should affect lateral return of the shifter. |
#5 |
Yes i did reinstall the shifter support bushing. hmm im thinking i reinstalled the shifter the wrong direction or i lost one of the bushings. well i found it but thats probably what it was. ill reinstall it and post back if it was. thanks!
#6 | |
Drives: FRS
Sounds a lot like what my issue was but if it works it works! Sent from my iPhone using Tapatalk |
#7 | |
Thanks! |
#8 | |
Drives: FRS
Ahhh that makes more sense then. Well if not that then I can’t be much help but maybe someone else has some ideas Sent from my iPhone using Tapatalk |
#9 |
No worries. I actually found whatever i didnt reinstall back
#10 |
Drives: FRS
#11 |
Gonna be either 35025. Per @EndlessAzure
| STI Short Shifter gets stuck on downshift. | RotARy15 | Issues | Warranty | Recalls / TSB | 5 | 10-18-2019 03:48 AM |
| Shifter Stuck at Shift Gate Occasionally? | jc7993 | Issues | Warranty | Recalls / TSB | 21 | 05-20-2019 04:31 PM |
| Reverse lock out button on IRP short shifter is stuck due to my dumb self | Mdulin | Engine, Exhaust, Transmission | 4 | 01-28-2019 06:44 PM |
| The (kinda) going back to stock sale-Tails, IRP shifter, shift light, catch can | Bent42 | Canada Classifieds | 7 | 12-10-2018 11:45 AM |
| Shifter Stuck | Strife26 | Engine, Exhaust, Transmission | 5 | 08-02-2017 10:18 AM |
