Old 05-23-2020, 07:24 AM   #141
T0rt0r0
Drives: European gt86
Could you share the link for the spoiler please ?
Do you think it covers oem holes ? (Pre-17)
Thanks !
T0rt0r0 is offline   Reply With Quote
Old 05-25-2020, 01:21 AM   #142
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Hate to be a kill joy, but there is a good chance the paint could fade over time.
I replaced a side mirror for my lancer back in the day. $75 aftermarket versus $265 OEM, but it was apparent within a year or two where the extra money went, and it was to the paint. The aftermarket one looked identical, but the clear coat slowly faded over the year, and eventually, it was matte black. They either skimped on quality or on the layers of paint. Hopefully that isn't the case for you.
You may very well be right, but this car will rarely see miles put on it so I don't imagine it fading quickly. Plus I looked it over and it really looks nice. And it was recommended to me by a friend who has both an authentic TRD and this exact rep and has had them for over a year without complaints. He told me get the replica because it fit just as nicely as his authentic TRD so I did. Fingers crossed it lasts and doesn't fade on me!
Thanks !
This actually has 2 threaded holes at the bottom to secure it with. I had a wingless trunk so I did not utilize these threaded holes, i'm just using 3M double sided tape and it seems extremely secure as it. I am fairly confident it will cover all of your oem holes, as this is a TRD replica and the TRD one does cover the holes (pre '17). It does not come with any double sided tape so make sure you get some 3M and also use some isopropyl alcohol or similar to prep the spoiler and trunk surfaces before applying the tape.
https://www.ebay.com/itm/Fit-Scion-F...K/303353540088
You may have a different color so look around for the correct one.
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
Old 05-28-2020, 01:59 AM   #143
solidsnake11
Drives: brz
Originally Posted by Clash0901 View Post
vvti is about $3k, non-vvti is closer to $4k but that's for a stock, crappy old engine. Not worthy of putting into anything and running it since it will at the very least have a few leaks. Needs to be completely gone through and at the very least replace all gaskets, vacuum lines, oil pump, water pump, and timing. But if anybody wants to make real power building the head is definitely recommended.
My old 2jz corolla put 835rwhp though a turbo 400 with stock untouched head. It did have hks 272s, rest of the long block was stock Toyota. The more boost the smother it will run.
2jzs are awesome to say the least.
The oil pump, if its not modified try not t rev it cold, it will blow out the front main seal. Another very common problem is the crank reluctor separating from the crank cog. To fix it just tach it on with a tig. The coils also get tired and start missing on high boost new OEM coils fix this. That's about all that goes wrong with them.
Great job with your swap!!!
solidsnake11 is offline   Reply With Quote
Old 05-28-2020, 12:06 PM   #144
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I have a fluidamper crank to fix that issue! And as far as coils, i'm just using the ones that came with it until I have to replace them with brand new OEM like you mentioned.
Old 05-28-2020, 01:35 PM   #145
solidsnake11
Drives: brz
I also had the fluidamper and the reluctor came loose, the seal blows out from the oil leaking past the oil pump and creating pressure behind the front main seal and pushing it out. The modified pumps have an extra drain hole behind the seal and small bolts to hold the seal in.
New coils are good to at least 1150hp at the crank, run platium plugs with the gap at .028 above 20lbs.
Old 05-28-2020, 02:04 PM   #146
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I'll keep the reluctor in mind and that's good to hear about the coils. I was skeptical about keeping them stock but that makes me feel better.
Old 06-01-2020, 10:26 AM   #147
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
New wheel and tire setup!
Fronts are VMS racing 17x8 ET35 with 225/45r17 Nitto nt05R's
Rears are VMS racing 17x9 ET35 with 275/40r17 Nitto NT555R
So far i'm super happy with the setup. Fitment is literally right where I wanted it to be.
Old 07-29-2020, 11:06 AM   #148
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
A tiny baby launch with a little 2 step in the beginning. And to think i'm considering parting ways with this car possibly... Hmmmm
Old 07-29-2020, 12:44 PM   #149
86fun
Drives: 2013 FRS
Awesome! Why considering parting ways? I might get mine swapped next year, so I'm curious.
86fun is offline   Reply With Quote
Old 07-29-2020, 01:52 PM   #150
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I'm not sure what is over the horizon but at this time i'm trying to save heavily for a down payment on a new home. For the right price, I would sell it to achieve that goal a little sooner. I'm nervous to even try listing it for sale though, because i'm not sure what to ask or what I should expect to get for it.
Old 07-29-2020, 07:28 PM   #151
nashcarr
Drives: 2020 BRZ tS 247/300, 1995 Miata
Keep the car and save longer for the house. Trust me.
nashcarr is offline   Reply With Quote
Old 07-30-2020, 04:08 PM   #152
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
That's likely what will happen. I'm in my first home still but garage space is super limited. I've made it work this far I may just keep going for another couple years until I have enough to buy another home.
Old 08-01-2020, 05:07 AM   #153
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Don't buy now. Prices are dropping, but there is still too much interest because of people rushing to buy because of the housing drought we have been having that prices are still too high. Wait for the foreclosures in another year after the market crashes more, until after the unemployment checks end, and until evictions finally start happening.
Of course, by then, it'll be harder to sell the car if that is what you decide, but I say keep the car like nashcarr. It is an awesome sleeper with one of the best engines ever. I miss the sound and top end of my mkiv. I never should have sold either of them.
Old 08-03-2020, 12:45 PM   #154
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Yea i'm thinking the same. If I wait it out another year, I won't need to sell it.
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 06:07 PM
Custom Grill Duct Backyard Build, Opinions? Doobster Cosmetic Modification (Interior/Exterior/Lighting) 22 08-04-2017 05:20 AM
Giving flat black wheels a dash of bronze? Expert backyard painters want to weigh in? Keenercarguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 06-02-2017 10:15 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 11:15 PM
Rwd-boxer's backyard exhaust fix RWD-boxer Engine, Exhaust, Transmission 9 06-11-2012 07:15 PM
