Drives: 2017 Fr-s
What mods needed to turbo a FR-S
Hello. Sorry if i dont know how to use the forum, i just created this account. I have a stock 2017 FR-S and i was wondering what mods are needed in order for the turbo kit to be stable inside of the vehicle, and so i can get the most use out of the kit. If anyone can give me a full list of mods needed before the turbokit, i would be very happy.
#2 |
Drives: 2017 Fr-s
If there is an order for the mods to be installed, putting them in order would be very useful. Thank you so much.
#3 |
Weight Weenie
Drives: 15 FR-S
#4 |
Have you searched the forum yet? I can't believe there isn't a thread or 5 about this already..
Sent from my SM-G975U using Tapatalk |
#5 |
And you don't always need half the things that people recommend.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#6 |
Rust bucket enthusiast
If you don't want close to / more than 300WHP, just buy a base model turbo kit, and something to tune it with. I would recommend ECUtek, but it sounds like you're going for the Cheap / Fast style build.
As you'll find is advised here commonly, do not take on a turbo project if you do not have a lot of money to burn. The turbo kit is the cheap part. This is not something that can be done reliably on a budget. If you just want to figure it out and want to start cheap, get the OpenFlash Tablet, and the SBD turbo kit. Let your tuner know that you're just looking for mid 200s and if they're sensible, they'll get you to that mark and you won't need any power supporting mods like injectors, fuel pump, clutch, nothing. The only thing you need to be mindful of is your temperatures and installation. A turbo kit introduces a lot of possible failure points. A severe oil or coolant leak will spell death for your engine if you let it go unnoticed. An exhaust leak at the flanges will introduce a lot of fuel correction, and a tune that loads the engine up with low end torque will bend a rod quickly. All in all, no matter your choice, budget 10k if you want to feel safe with whatever you choose. No, I'm not kidding. |
#7 |
Jebus I know these kits are pretty standard and will run on whatever handheld tune but why is everyone so against a professional tune on a dyno? I think it's worth the money just watch the pull. I am down to try almost anything parts wise but I would just rather a pro tune my car than try it myself or use some one-sized fits all approach. Then again most of my modded cars (BRZ is mostly stock) are not that standard (even for aftermarket).
#8 | |
Drives: 2017 Fr-s
#9 | |
Drives: 2020 86
#10 |
has a funny hat
Drives: 2014 BRZ Limited
sounds like you have the budget. K swap or LS swap, then worry about a turbo.
#11 | |
If you want less than 300WHP, that should be all you need. Only datalogging and your tuner can guide you after that; nobody here can tell you if you're overheating or running out of fuel. You could get some injectors just as a precaution, but depending on your goal, they may be unnecessary. Nobody will be able to tell you what wheels/tires you should get, as your grip will be determined by the way it is tuned and the way you drive. The only thing I'd do is get the Exedy stage 1 clutch. It drives like the stock one, but holds quite a lot of torque. I'm using it and it held my 330WHP without a problem. |
#12 | |
Drives: 2017 Fr-s
#13 |
Drives: 2017 Fr-s
Sorry, im new to swapping engines but doesnt that introduce alot of problems or am i wrong? If anything i would like to put either a RB25 or a RB26 in to it. (sorry for sounding like a RB fanboy)
#14 | |
Buy a basic turbo kit like one of the following- JDL FullBlown Greddy 518z SpeedbyDesign Ptuning Get the Exedy stage 1 clutch Get the ECUtek dongle + Cable, get the ECUtek license, get the ECUtek RaceRom patch Get tuned, get fast. |
| Tags |
| forged, help needed, turbo, turbo fr-s |
| No longer needed, mods please delete | wheelsun | Software Tuning | 0 | 08-11-2016 03:17 AM |
| No longer needed, mods please delete | wheelsun | Want-To-Buy Requests | 0 | 08-11-2016 02:11 AM |
| Turbo kit needed | Cuztomizer | Want-To-Buy Requests | 0 | 11-30-2015 08:34 AM |
| Rocket Bunny V2 Bumper - Mods Needed? | HachiRo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-10-2015 12:33 AM |
| FA20CLUB turbo kit advice needed | joedaniali | Forced Induction | 26 | 02-24-2014 02:25 PM |
