Old 08-25-2020, 11:31 AM   #72213
Cars.. boats... airplanes... They all have their uses.
It is generally accepted that cross using those three things is a bad, bad idea.
With one exception...
Tcoat is offline
Old 08-25-2020, 11:49 AM   #72214
p1l0t
p1l0t's Avatar
Yeah I prefer them separate. Purpose built.
p1l0t is offline
Old 08-25-2020, 04:16 PM   #72215
ls1ac
ls1ac's Avatar
ICON A5
That's the one i want.
Put it on a trailer take it south for the winter.
I know a couple of bad decisions by pilots but it still looks good. To bad its at least twice the price i could afford, even with a friend.
ls1ac is offline
Old 08-25-2020, 05:01 PM   #72216
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
It’s already configured actually. Just from plug and play I can see oil temp, coolant temp, AFR, revs, voltage, intake temp (I think but haven’t confirmed).
There are also two analog input wires that can be connected to additional sensors I believe.
I think you can also reconfigure values for stuff like the meter on top, since it shows the number and some kind of meter maybe as like a way to quickly glance and see if there’s too much of whatever the value.
Then there’s also some timer type things for 0-60 and other measurements.
It is air intake tamp. Also boost, egt, ignition timing, speed, throttle, and a 0-60 timer. I'm still in debate about wiring the optional boost sensor to read over 5.2 psi, or if I should just get a 2 bar map sensor and tune for it.
ScoobsMcGee is offline
Old 08-25-2020, 05:11 PM   #72217
spike021
spike021's Avatar
Ahhh, thanks for the confirmation.
I don't need to worry about boost since I'm NA but all of those other metrics are super useful to have, and the interface works well for me so far.
I like that it's extendable though, it's cool that they build it so you can add sensors depending on your build and how you want to use it.
Instagram: @spike.grc
spike021 is offline
Old 08-25-2020, 06:36 PM   #72218
spike021
spike021's Avatar
@ScoobsMcGee how'd you secure the ribbon cable?
I went out earlier and it turns out I didn't do a good enough job and it's drooping into the footwell.
I had originally ziptied it but fairly loosely to the factory bundle of cables under there.
I'm terrible with routing and I know ribbon cables are fragile so I don't know how else to keep it from dangling.
spike021 is offline
Old 08-25-2020, 06:47 PM   #72219
ScoobsMcGee
I zip tied it to the metal bar that the bottom of the dash connects to. Not overly tight, but enough so that it hasn't fallen off in just over a year since install.
Old 08-25-2020, 09:19 PM   #72220
Originally Posted by ls1ac View Post
ICON A5.
I've crawled over, under, through, around the A5 everytime I see it at Sun N Fun or other airshows. I want one so bad.
It's way overpriced though, particularly for a sport plane. But damn its sexy. I'll just have to settle for flying it in MSFS.
Dadhawk is offline
Old 08-25-2020, 10:00 PM   #72221
One like this landed in the lake at our cottage on Saturday. Had to look it up.
There is one of these sitting on the small private airfield by my work. Just showed up about a month ago. Can't be more than a couplel left in the world so have no idea why it is there.
I got to ride in one of these once. Taking off and landing in the water is nuts!
Tcoat is offline
Old 08-25-2020, 10:19 PM   #72222
C-JGIB is a Searey not an A5. Whole different class of airplane, although they look similar.
You can check out the Icon here.
Dadhawk is offline
Old 08-25-2020, 10:27 PM   #72223
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Captain Snooze is offline
Old 08-25-2020, 10:44 PM   #72224
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
She does not look too happy to be photographed.
Also, that seems like a nice place for a cottage.
Spuds is offline
Old 08-25-2020, 11:31 PM   #72225
soundman98
ProCrastinationConsultant
soundman98's Avatar
"i swear, i'm taking a picture of the plane!"
soundman98 is offline
Old 08-26-2020, 05:34 AM   #72226
I know. I just meant a plane like I pictured not one like yours
Not my picture! Not nearly that nice.
Tcoat is offline
