| Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: UK GT86
Here is the simple explanation of how it works: Pedal at 40% @ 3600rpm - Requested Torque = 172.8 Requested Torque base @ 3600rp = 193.5 172.8/193.5 = 0.893 Now on the Target throttle position table: (x axis) 0.893 @ 3600rpm = ~35 Degree throttle My Calibration Spreadsheet Has a DBW tab at at the very right that calculates it all for you. On that, the WOT threshold is known as Requested Torque base in RomRaider.
.: Stealth 86 :.
#16 | |
The Mechanic
Drives: Civic Turbo,FR-S
#17 |
Drives: UK GT86
No, it obviously hasn't been defined. Which ROM are you using?
.: Stealth 86 :.
#18 |
The Mechanic
the open flash rom 2.062 and ZA1JA00C xml.
#19 |
Drives: UK GT86
These should work:
Code:
<table name="Requested Torque Base" storageaddress="13C528">
<table type="Y Axis" storageaddress="13C4CC" />
</table>
<table type="2D" name="Requested Torque Base" category="Drive-by-Wire Throttle (DBW)" storagetype="uint16" endian="big" sizey="23" userlevel="1">
<scaling units="ECU Value (Raw)" expression="x*.0078125" to_byte="x/.0078125" format="0.0" fineincrement="1" coarseincrement="10" />
<table type="Y Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P2">
<scaling units="RPM" expression="x" to_byte="x" format="#" fineincrement="100" coarseincrement="1000" />
</table>
<description>This map is used to calculate the percentage of maximum torque.</description>
</table>
.: Stealth 86 :.
#20 | |
The Mechanic
#21 |
Drives: UK GT86
Place the top code with the addresses in the upper part of the definition and the part where it says table type =2D with the rest of the DBW stuff of the lower half of the definition. You'll see that the definition should be in 2 distinct halves, with a separation phrase in the middle.
.: Stealth 86 :.
#22 | |
The Mechanic
now if my requested tq is higher then my torque base say 207req/ 200base i get a 1.035 such as the stock maps are. That should be using the 1.0 raw ecu value from the target throttle position table since thats the max, but thats set to 102.4 stock and the throttle body is open only to 90%.?? There is somthing i dont understand here, do the calculated tq tables come into play?
#23 | |
Drives: UK GT86
![]() I honestly don't know what the calculated Torque tables do, and from what I've read on Romraider and NASIOC I can't come to any conclusion.
.: Stealth 86 :.
#24 | |
The Mechanic
#25 |
Drives: UK GT86
You can't, it's just what the TB does.
.: Stealth 86 :.
#26 |
The Mechanic
Oh. I thought u said you got yours to stay open liniar. Meh then i guess ill just fix that full throttle at 70% thing
#27 |
Drives: Subaru BRZ 2016
Thank you for the Requested Torque Base info @Kodename47. I made my throttle linear but I had to reverse engineer the torque ratio denominator because I did not have the Torque Base defined in my xml file. I wish I had seen this thread earlier and saved some time!
| AFR table | nickw14 | Software Tuning | 9 | 04-01-2015 06:14 PM |
| f.s. Open flash table | slofrs | Engine, Exhaust, Bolt-Ons | 3 | 12-31-2014 11:07 AM |
| 2014 PAX table | Scooby South | Tracking / Autocross / HPDE / Drifting | 11 | 11-26-2013 11:35 AM |
| Help posting a Table / Spread sheet | Esoteric | Site Announcements / Questions / Issues | 1 | 07-28-2013 12:48 AM |
| Coffee table I made from my FRS OEM springs | FR-Shadow | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 12-16-2012 07:05 PM |
