Old 09-20-2020, 03:58 PM   #1
gpvecchi
gpvecchi's Avatar
Can't decide suspensions
I actually have the Sachs dampers with JDM STi springs, but I'm not happy.
I'd probably not benefit of coilovers, as I don't track and I don't want to adjust height, so I thought of staying OEM.
Which is the lowest and which one the best for street between tS/STi suspensions? I read that claimed lowering is not correct...
Showa 2013 tS, Bilstein 2015 tS or Sachs 2018 tS/STi Sport?
Thank you!
Old 09-20-2020, 04:24 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
What aren't you happy with?
TommyW is offline   Reply With Quote
Old 09-20-2020, 04:38 PM   #3
Racecomp Engineering
I would just add Bilstein B6.
- Andrew
Old 09-20-2020, 06:01 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
My vote goes to Bilstein. Ran them on my e36 cars, super nice
Old 09-20-2020, 06:38 PM   #5
TommyW
TommyW's Avatar
- Andrew
Better than the B8 for lowered cars?
Old 09-20-2020, 09:29 PM   #6
They both have the same excellent valving (oh and we were there for some of the development ), but B8 has less droop travel. We recommend B6 in almost all cases.
- Andrew
Old 09-21-2020, 02:15 AM   #7
gpvecchi
gpvecchi's Avatar
Front is too soft and bouncy and rear is too stiff.
I was thinking of specific 2015 tS Bilstein, but I read that it almost doesn't lower and it's harsh.
Old 09-21-2020, 04:41 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have the 2015 tS Bilstein suspension in the MY14 car and before that I had the Sachs performance coilovers (not the factory Sachs). The height difference with the Bilstein is 15mm. The gap between tire and fender in the MY20 car is 4 fingers, while in MY14 is 3 fingers.
Overall, I wouldn't go much lower in that car. You'll lose too much length on suspension stroke and there isn't much from factory. Fact is that 15mm lower doesn't show that much, but it is still lower ...
About feeling, I wouldn't say it is harsh. In fact when I changed from the Sachs coilovers to the tS Bilstein the feeling was that the car was more compliant. Of course, it is sportier comparing to stock. If you are looking on something with comfort, then it is not the best option.
Old 09-21-2020, 08:42 AM   #9
gpvecchi
gpvecchi's Avatar
Thanks! Could you please post a precise measure of the heights? I read that tS Bilstein springs lower less than 15 mm (that I find perfect).
Old 09-21-2020, 10:58 AM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't have the precise measures now. The suspension takes a bit of time to settle the springs.
Old 09-23-2020, 05:34 PM   #11
gpvecchi
gpvecchi's Avatar
I'm almost convinced now; did anybody has the opportunty to compare the 2013 tS Showa with the 2015 tS Bilstein?
Old 09-24-2020, 01:51 AM   #12
HaXx
Drives: jrsc_brz
i believe the trd lowering springs are the lowest lowering springs. rce yellows do not lower as much as the trd. and it seems like you want to keep OEM+ parts.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 09-24-2020, 01:57 AM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Check this comparison review (2013 tS v. 2015 tS) here:
"Next, the point upgraded from the previous 2013 BRZ tS is the adoption of Bilstein dampers. The Bilstein damper has a quick expansion and contraction response, so even if the damping force is lowered, it will damper properly, so compared to the previous 2013 BRZ tS damper, the damping force is stronger only on the front extension side. .. After that, the damping force is reduced to make it easier for the legs to move smoothly.
With this, I got a more supple ride, but I felt that the most remarkable effect of the building foot this time was the reduction of pitching in the high speed range. Personally, I thought it was natural for a sports car to have some pitching in the high speed range, but after all, if the pitching is reduced, the quality of the ride will be greatly improved.
Also, I had the illusion that the amount of roll increased due to the supple movement of the legs, but the amount of roll has not changed from the previous 2013 BRZ tS. By the way, the spring rate is the same as the previous work (10mm lower than normal)."
(Google translate)
https://autoc-one.jp/subaru/brz/repo...9312/0003.html
Old 09-24-2020, 02:19 AM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Having said the above and driving a '20 BRZ with the latest Sachs dampers (20310CA280/-90, 20365CA240) and stock springs, I can say that the Sachs dampers are better comparing to the Bilstein tS dampers. My initial thought was to swap the Bilstein tS suspension to the new car, but after driving it is not needed anymore. I believe that they managed to increase the damping quality and performance by continuously improving the dampers quality and chassis rigidity. Only issue is the stock height, but if the car color is dark it hides the wheel gap enough.
FS: BRZ / FRS OEM Brake Kits + Suspensions J_Lin Brakes, Suspension, Chassis 1 03-01-2017 01:20 AM
ST Suspensions Coilovers!!! FBPARTS Brakes, Suspension, Chassis 3 12-03-2015 02:38 PM
Any air suspensions? Danny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-16-2013 12:56 PM
BRZ suspensions Subabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-18-2013 02:56 PM
Buttonwillow Pictures by JRZ Suspensions renzo1982 Tracking / Autocross / HPDE / Drifting 41 12-19-2012 03:36 AM
