Old 11-06-2020, 11:08 PM   #155
CSG Mike
CSG Mike's Avatar
Originally Posted by aKaGorganZola View Post
With the long press it switches to a more "normal car" hot cold range versus actual temp. I don't know why anyone would want the hot cold range vs the numbers imo lol.
Most "normal" people freak out if the gauge even slightly moves, so it defaults to the no-number scale, and "normal" will be anything from 170F to 220F.
Old 11-08-2020, 01:29 PM   #156
jflogerzi
jflogerzi's Avatar
Originally Posted by Kodename47 View Post
@randomthoughts that looks like it would be really hard to actually read when driving and there is repetition across the screens/tabs.
I have 2 main screens with actual useful info that you might want for driving and then the rest are there just for datalog info. While it's great to fill a screen with info, much better to have minimal info of useful data.
Why RPM? - it's on the dash in front of you
Throttle angle - not useful unless mapping the throttle (even then I'd just mark and use logs.)
AFR - I think the graph works well with target and output
Temps - Air/Oil/Water - set on dials with min and max set works well
MAP and MAFs - same as above
VVT on - Is 1/0 so you can have that as a bar/number/dial as you see fit
VVT angles - also a worthwhile parameter
Here's mine for ref:
Can share this template?
2013 Series 10 FRS #553
Old 11-09-2020, 06:51 PM   #157
Kodename47
Kodename47's Avatar
Drives: UK GT86
@jflogerzi Download Here
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-19-2020, 07:14 PM   #158
mike_b
Drives: 18 BRZ
Question on ECU Connect. Can it be used to generate logs for cars that have not been previously flashed?
mike_b is offline   Reply With Quote
Old 11-19-2020, 07:17 PM   #159
Kodename47
Kodename47's Avatar
Drives: UK GT86
I believe so yes but not all the parameters will be available.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-26-2020, 11:50 AM   #160
mike_b
Drives: 18 BRZ
Confirmed. Not all parameters are available but most of the important ones are.
Old 11-26-2020, 12:23 PM   #161
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Just a PSA here- the Atoto A6 toyota spec is back. This headunit works with ECUTEK's bluetooth setup.
https://www.amazon.com/gp/aw/d/B075W...b_b_asin_title
Old 11-26-2020, 08:01 PM   #162
sroby
Drives: 2015 Firestorm 08/05/15
[QUOTE=Luftwaffel;2787657]Yes it says specifically on their website that it supports anything ProECU supports.[/QUOTE
sroby is offline   Reply With Quote
Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM DeliciousTuning Software Tuning 331 06-17-2025 03:36 PM
My Bluetooth in my 2014 FRS so stay connect Case1010 Electronics | Audio | NAV | Infotainment 3 02-24-2016 07:57 PM
Header/overpipe interface misooscar Engine, Exhaust, Transmission 4 11-23-2014 12:21 AM
Garmin GPS Bluetooth Won't Connect frssfo Electronics | Audio | NAV | Infotainment 0 08-20-2014 11:55 PM
Bluetooth connect mutes android NAV Rob_g Electronics | Audio | NAV | Infotainment 6 07-04-2012 05:38 PM
