#2381 | |
Actually, I'm surprised keyboards haven't just devolved into a LCD touch screen with SWIPE, since that is what most people use 90% of the time anyway. Probably more costly than a $5 throwaway keyboard which is the problem.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#2382 |
friendly
Drives: 17' 86
Been using my rx6800 for a few days, thing flies at 3440x1440
Seek comfort in discomfort.
#2383 |
Drives: Mazdarati
#2384 | |
#2385 | |
The Dictater
Drives: '13 Red Scion FRS
#2386 |
Because compromise ®
Drives: Red Herring
From the few reviews I have bothered to watch re the RX6800 I am thinking that this will be my next graphics card. The RX6800XT's negligible increase in performance doesn't warrant the increase in price.
I have gone anti Nvidia because of this:
#2387 | |
ProCrastinationConsultant
#2388 |
Drives: 2018 Subaru BRZ
Could I get some input on this possible set up? Im a noob, like I mentioned earlier on the thread. I'm still missing a video card. I was thinking RTX 2060 but is becoming quite hard to find. The budget is about $1000 more or less.
This is what I got so far. CPU: AMD Ryzen 5 3600 6-Core 4.2 Ghz Max Boost SSD: XPG SX8200 Pro 1TB Motherboard: MSI MPG X570 Gaming Plus Cooling: Cooler Master Hyper 212 Evo 4 CDC Heatpipes, 120mm Fan Power: Corsair CX Series 450 Watt 80+ Bronze Certified Case: NZXT H510 Ram: Corsair Vengeance LPX 32GB (2X16) 3200MHz Video: N/A
#2389 |
Rust bucket enthusiast
I wouldn't future-limit yourself. If you want it to be good for a while, get something with 650-700w. It won't use the wattage, but will often come with cables and connections to support beefier things in the future. 450w may be adequate, but if you're doing a build, don't shoot for " adequate". There's not really a cost difference between 450 and something in the 700w range. You'll thank yourself for having overhead someday.
I would also suggest getting something that's modular. Not necessary, but cleans things up and the convenience is worth the extra cost https://www.corsair.com/us/en/Catego.../CP-9020061-NA This would be my suggestion
#2390 | |
Sweet. Like I mentioned, I'm shooting for a little over $1000 but I'm open to any improvements on the build, It will be my first build ever. Any suggestions on RAM and Videocard?
#2391 | |
On the GPU, if you are gaming this will be the most critical part of the build. Basically, buy the best card you can for the budget you have. Look at speed tests on Tom's Hardware and other such sites then find the one that matches your budget. I typically buy one level down from the top tier because the top tier usually have a stupid amount of geek tax associated with them. It's likely your build will survive a couple of video card upgrades in the future. I've found that I usually upgrade video cards every two or three years and buy/build a whole new system every 6 to 8 years. I'm not typically running games at the bleeding edge though as I actually prefer it with some of they eye candy turned down a bit.
#2392 | |
The RAM should be completely fine, there's not really a need to shoot for something with lowest latency / highest operating clock speeds unless you're shooting for benchmarking world records.
#2393 | |
Right now is the new RTX 3080, but is going for almost $800, if you can find it, that is. The 2060 is more than capable and is fraction of the cost, but is hard to find right now. Is just about the only thing that I'm missing on my cart.
#2394 | |
I don't track NVidia closely because I've always preferred AMD/ATI. My current systems has a RX5700XT (it was built earlier this year). That's considered a "second tier" card at this point, but I'm very satisfied with it. It runs everything I've thrown at it in 1920x1080 with no issues, including MS Flight Sim 2020 and VR. It also runs 3x1920x1080 games with no issue. This might fit into your budget and I've seen availability on it. The price for it is also jacked up a bit though since availability of top tier is almost zero.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 01-05-2021 at 01:59 PM. |
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 05:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 07:37 PM |
