Old 03-10-2021, 12:40 PM   #15
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I hate to say this, but I suspect that this particular car has more problems with it than just missing parts, which is why the previous owner got rid of it.
To OP: Please keep us updated on your issues.
My pubes are shaped like the number 86. There for I知 car. Derp
Count to muffens and call again.
I知 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 03-10-2021, 12:45 PM   #16
ls1ac
ls1ac's Avatar
With the E85 kit removed by the PO is it even tuned for E85 or has it defaulted to gas.
Should have test driven with PO before buying. Should have bought a running car with needed parts.
Old 03-10-2021, 01:33 PM   #17
Yep. This could just be tip of the iceberg.
Old 03-10-2021, 04:45 PM   #18
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Might be worthwhile looking into legal options (not sure if you have any recourse under a private sale)
daiheadjai is offline   Reply With Quote
Old 03-10-2021, 05:00 PM   #19
Originally Posted by Grady View Post
Where are you in Dallas? PM me if close I could swing by.
You da man!
Old 03-10-2021, 05:05 PM   #20
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Not here in the States, unless the seller KNOWINGLY falsified the odometer reading.
Old 03-10-2021, 06:10 PM   #21
Ashikabi
Ashikabi's Avatar
You're wrong in this case.
His ECU is still tuned for flex fuel. His ECU is looking at whatever is plugged into the ECU's input of the rear O2 sensor, be that the output of an Ethanol content analyzer or an O2 sensor. It's expecting to see the output of an Ethanol content analyzer, but now it's seeing the output of an O2 sensor, which fluctuates with the actual exhaust gases in the pipe after the rear catalytic converter.
The people that are running straight E-85 have a specific tune for that mix and don't require an input on the O2 sensor wire to the ECU to tell the ECU what the Ethanol content of the fuel is. It's predetermined by the tune. That's the main difference between a flex fuel tune and an E-85 tune.
And remember, most pump gas these days already have up to 10% Ethanol in it already.
The ECU needs to be reflashed to stock or he needs to install a new flex fuel kit.
EDIT: And then figure out where that smoke is coming from.
That's gonna depend on the kit. My flex fuel kit retained both o2 sensors and used a third input from the ECA. I believe the newer Delicious kits use the rear O2 plug for the ECA input. So depending on the kit, I might still be right.
Sent from my ONEPLUS A5010 using Tapatalk
Old 03-10-2021, 06:39 PM   #22
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Okay, I'll give you that. But since the OP originally said that he was getting upstream O2 related codes and didn't mention any downstream related codes, that tells me that the tuner may have disabled the downstream codes from being able to trigger a CEL.
One thing the OP didn't mention though, is if the headers that the seller had in there before he sold it were catted or not? If they were not, I would tend to think that the tuner used the O2 input instead of the EVAP input....Which is one reason why the OP should get back with some questions to the seller.
Old 03-10-2021, 07:03 PM   #23
Ashikabi
Ashikabi's Avatar
If it's tuned, it's very unlikely to have downstream codes regardless of kit
engine, headers, help!, problem
Engine oil recommendations for turbo cars Turbo Forced Induction 25 06-25-2018 06:33 PM
The Smoking Tire: V6 MR2 mb_ Other Vehicles & General Automotive Discussions 16 05-24-2015 01:38 AM
How many quarts of engine oil for cars with oil coolers toby714 Engine, Exhaust, Transmission 8 12-11-2014 08:16 PM
future engine configurations...and the cars they go into cdrazic93 Other Vehicles & General Automotive Discussions 1 10-08-2014 12:42 AM
Engine Swaps and Kit Cars! merlin2111 Other Vehicles & General Automotive Discussions 27 01-27-2012 06:18 PM
