#5685 |
Drives: Subaru BRZ 2017
I've read through every pages spanning 2014 till present.. and I've doubts back and firth so I decided to pull the trigger.
I'm driving 2017 BRZ AT and it's my Daily. I would like to have power No MORE than 300whp while keeping most things stock. I'm currently running JDL UEL (ceramic coating) and catless resonated front pipe - basically straight pipe. I've been on ecutek flex tune [for about a year now]...so I do run e85 very now and then (more like E70 in my area doesn't really go above that at most) I won't be doing much of any track or auto crossing (so basically 99% street driving) Question is what kind of power would I be getting on 93 tune (with stock pulley) and running between E60 - E70 with my current setup? I've read you won't need to swap out Injectors or fuel pump when on pump gas. I'm most likely going to upgrade injectors anyway based on my reading..but since I might be running ethanol on several occasion while trying to tamper the power @ or below 300, would I still need to upgrade fuel pump? Thank you. |
#5686 | |
Drives: Series Blue WRB JRSC C38 HBP Flex
#5687 |
Ultra Senior Member
Drives: 2014 BRZ Premium, WRB
From everything I’ve read you should probably upgrade to a higher flow pump since you need to flow something like 20% to 25% more fuel when using ethanol (others will keep me honest here). Starving your engine of fuel because you don’t have enough flow is apparently pretty bad and can result in engine damage. I suppose you could tune it so that your not over working your current fuel pump on ethanol, but I would expect you’d be leaving some power gains on the table.
#5688 | |
Alright. |
#5689 |
Ultra Senior Member
It doesn’t really have anything to do with how often or seldom you use ethanol. An experienced tuner might have a more technical answer, but I believe the idea is that if you are pushing past the flow limit of the fuel pump on ethanol, you might end up leaning out the AFR which I believe leads to detonation. Do that enough and the engine goes boom.
#5690 |
#5691 | |
Ok for real I think I might as well.. I'm guessing I went be needing catch can also and oil cooler. I do have the oem 'foster' install currently... Not much but brings my temp down about 8 to 10 degrees.. |
#5692 | |
Do it right the first time, or you may find yourself doing it over and over, and wasting a lot of money in the process! |
#5693 |
#5694 |
#5695 |
#5696 |
#5697 |
Ok Apologies for the confusion. I am asking in terms of street use which one is favorable long-term-wise at 300whp max? and How the low/mid/top [end] ranges fair in comparison
#5698 |
They all build boost somewhat linearly, and with identically good tunes, will all be roughly identically reliable.
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
