Old 07-06-2021, 11:07 AM   #23199
DocRecon
Muscle Car to Import
DocRecon's Avatar
Drives: 2013 Asphalt FR-S
Getting ready to throw Deatschwerks 700cc injectors into my supercharged FR-S, along with a new Raceseng cam plate. All tuning has been provided by Zach @CounterSpace.
DocRecon is offline   Reply With Quote
Old 07-06-2021, 11:33 AM   #23200
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I took the fuel pump housing out and took it apart. The fuel pump looked like it was installed too tight and the 3 O rings were bulging out, and the cup the fuel pump is in was a bit loose. The fuel starvation door looks like it is functioning as it should. Got it all back together, and got the new seals to put it back together. I hope this solves my fuel pressure issues.
Old 07-06-2021, 02:30 PM   #23201
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by Wally86 View Post
This was the first question a smart alec person asked on IG and I've turned off traction control exactly four times ever. Three times to do a single donut and one time to do a 180. All in parking lots. Never while normal driving. I'd say I'm old but everyone here will deny that 39 is old so I'm... aged? And unwilling to turn off nannies. All that said, I don't see how TC would have helped when I was off of the ground but I get the sentiment.
Compared to me, you should still be in diapers. I can't use the pedal dance before the car is warmed up, of course, but I always switch off the nannys. I believe in driving the car myself, and I've done a lot of instructing on the skid pad.
Qwimby1 is offline   Reply With Quote
Old 07-06-2021, 02:32 PM   #23202
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
That last sentence makes all the difference
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 07-06-2021, 02:51 PM   #23203
Qwimby1
Red face
I guess so, but I shouldn't have been tooting my own horn. Watch me tag the Armco next time out! FWIW, I'm very happy with my Firestone Firehawk Indy 500s here in rainy Florida.
Old 07-06-2021, 02:56 PM   #23204
It does. Like Quimby, I have a couple decades on you. Hooning in dirt/mud/snow since childhood, I tend to forget how much it has skewed my viewpoint.
Old 07-06-2021, 09:12 PM   #23205
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Drove mine to Lowe's, got some wood filler to fix some house details after the big project of new siding, trim, garage and entry door on the house.
Wife threw in some of that bubble wrap mylar stuff for a project in the RV since we're in the heat bubble. She wants to make some window fitting items out of the mylar bubble wrap for the baking side windows facing the heat. Will be much more challenging than our old vanagon westy 20 years or so behind us. Those windows had a full channel you just cut the perimeter and stuff it into for a good fit as I just checked the trailer. I had to use sunscreens from windows back then, which folded up nice. Have to just them up with this new kit. Helped a lot in the winter keeping the heat in. Banking on the same concept to keep it out this time. It'll give us something to do together.
A month or more ago I had an HKS Supercharger put on, woohoo. HKS base tune with the plug and play dongle. A discontinued kit option now.
Quite happy. Some suspension bits give occasional hop on takeoff, That's ongoing, the heat makes it worse.
jeepmor is offline   Reply With Quote
Old 07-09-2021, 10:46 AM   #23206
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Going to pick up a new battery today. I don't trust the original 6+ year old battery.
Old 07-09-2021, 11:18 AM   #23207
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Kudos for getting 6 years out of it.
BirdTRD is offline   Reply With Quote
Old 07-09-2021, 11:38 AM   #23208
We just replaced the battery in my son's 2002 Accord. The battery was almost 10 years old. Even at that it was performing fine until it went completely dead thanks to a bad brake light switch that drained it. Even then, it fully charged, but wouldn't hold the charge.
OK, it wasn't a bad brake light switch, it was a rubber grommet that broke. The Accord has a rubber grommet that is contacted by the brake light switch when the brake is not engaged. If that grommet fails, the brake light switch goes through the hole where the grommet was and the brake light stays on (thinking the brake light has been pressed).
We discussed doing a redneck fix by putting either a bolt or even a tie-wrap through the hole but ultimately we replaced the $1 grommet with a new one.
Old 07-09-2021, 12:26 PM   #23209
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Wow, must be the weather! 5 years is when I start battery shopping...if it lasts that long. Only got 4 years out of my OEM battery.
Old 07-09-2021, 01:25 PM   #23210
StraightOuttaCanadaEh
Wes
I got 3! Barely too, the last year it died on me several times and I had to be rescued
Instagram: @gt86ws
Old 07-09-2021, 01:52 PM   #23211
I was actually shocked when I saw the sticker on the battery. I would say I average 4years at most normally. My '13 86 is on it's 3rd battery now.
Old 07-09-2021, 06:25 PM   #23212
Mine gave out at, like 60,200 miles. I watched one of the cells slowly lose capacity for a couple years. Would love another factory battery for fun.
