#995 |
Drives: 86 GT
@steve99 @Kodename47 do you guys have the RR definition for OFT A01G that has the A/F #3 Learning Limits?
I see the table described in the def, but one of the entries is missing. @Kodename47 I suppose this link below goes to your latest defs but the A/F #3 Learning Limits is not there either. https://www.ft86club.com/forums/show...&postcount=411
#996 | |
Drives: FT86
if you have thise two #af3 parameters just zero those i think the third one in some defs is redundant or a duplicate ecutek only has 2 |
#997 |
Drives: 86 GT
#998 |
Drives: FT86
#999 |
Drives: 86 GT
Tune is based on Wayne's, so yes OFT v4. Another forumer was also seeing the same issue.
https://www.ft86club.com/forums/show...41&postcount=5 |
#1000 |
Drives: 2014 GT86
Compelica: I might be wrong .. but IIRC wayneroms were based on heavily reworked but OFTv3.
#1001 |
Drives: 86 GT
#1002 |
Drives: 2014 GT86
Compelica: then i might be reading wrong if it is as you say.
when searching on his site for "V4" in one changelog bit: "Apr 2018 Re-generated all USDM MY12-MY16 roms from A01G/I instead of B01C/D, for compatibility with Openflash V4." when at same Apr 2018 for Openflash Release History there is bit: "MY12-MY16 tunes are identical to OTS 3.0." On which base stock tune something is based on doesn't mean it's similar tuned as OFT v4. |
#1003 | |
Drives: 86 GT
#1004 |
Drives: BRZ 2015
Does anybody know A01G hex addresses for codes that come before P0011?
The list in Romraider -> Diagnostic Trouble Codes seems to start with P0011. Codes like P000A, P000B, P000B, P000B and P0010 are nowhere to be found. On GitHub I've found a definition file that says A01G but it's totally different from my A01G definition file I got from Wayno's website and this definition file just throws bunch of errors when I try to open my ROM. I've also tried to just use these addresses and add them to my definition file like so HTML Code:
... <table name="(P000A) CAMSHAFT POSITION A TIMING SLOW RESPONSE BANK 1" storageaddress="11E138" /> <table name="(P000B) CAMSHAFT POSITION B TIMING SLOW RESPONSE BANK 1" storageaddress="11E144" /> ... Last edited by TeeJay.net; 09-17-2021 at 04:36 AM. |
#1005 | |
Drives: FT86
ok none of the romraider definitions have those codes defined ecutek has them and its pisdible to disable those codes but they fo indicate you have a real problem and disabking those codes in tune wont fix the hardware issue |
#1006 | |
Drives: Toyota 86
HTML Code:
<table name="(P000A) CAMSHAFT POSITION A TIMING SLOW RESPONSE BANK 1" storageaddress="11C7C4" /> <table name="(P000B) CAMSHAFT POSITION B TIMING SLOW RESPONSE BANK 1" storageaddress="11C7D0" /> <table name="(P000C) CAMSHAFT POSITION A TIMING SLOW RESPONSE BANK 2" storageaddress="11C7DC" /> <table name="(P000D) CAMSHAFT POSITION B TIMING SLOW RESPONSE BANK 2" storageaddress="11C7E8" /> And the definition file in the link you've mentioned has weird DTC addresses. I don't know why td-d left those values incorrect, but suggest to use the definition file included in the OFT distributions. Keep in mind that since OFT v4, all definitions for manuals are based on A01G.
#1007 | ||
Drives: BRZ 2015
#1008 |
Drives: 2020 Subaru BRZ AT
opening my stock bin in rom raider
Im new and trying to learn so 2 questions.
1a. So i got my stock .bin and it wont open in rom raider the CAL id is ZA1JV01D00G i get a bunch of errors trying to open it? do i need compatible DEFs for it to open? 1b. Im trying to look at the stock values cause i want my stock cold start on my stg 2 tune.. is that possible to do by copying the (Idle Speed Targets A-F, Ignition Timing Post Start, and MAF correction before start Neutral and in gear)? or will it mess things up? Thanks! |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 01:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 11:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 09:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 11:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 08:27 AM |
