#127 |
BAMF
#128 |
Drives: 2013 Black FR-S
#129 |
Drives: 2013 raven black fr-s
I'll have mine dyno'd in a couple months. We are goign to try and keep the car mildly modded, but want to see normal temp dyno runs around here, since this car performs better in hotter weather
#130 |
Drives: 2jz
@vividracing waiting for all the data to be added on the first page. thanks
#131 |
I just spent the last two hours adding more Dyno info. I'm going to bed now I have to be at work in 3 hours.
#132 |
Drives: subatoy
THIS IS AWESOME! great job guys!
I have a question. how much would the cost of ALL the parts used be? Agency Power Header $600 Agency Power Cross-Pipe $400 (this is a place holder I couldn't find price) Agency Power Catback $850 Agency Power Pulley $130 Total: $2,000 (estimate) not including labor. Taking into consideration that a turbo Kit running 4psi will cost $5k and basically give you the same results, this is not that bad, plus you retain NA drivability. Last edited by subatoy; 07-30-2012 at 10:52 AM. |
#133 |
Drives: Scion FR-S | 6MT | Ultramarine
Ooh. Interesting data. Is it just me or is the header not doing much?
#134 |
Drives: Raven Black
PM for the price on the cat-back and the pully please.
Also - quick question: all these dyno pulls are showing the results of just bolt-ons with no tuning of the AFR right? What affect are the bolt-ons having on the AFR? hopefully its not leaning out the engine too much? Props to all this hard work BTW!!!! |
#135 |
Drives: 2013 Scion Frs(Scarlet)
^ im wondering same thing...i love this setup, and the gains i see across the chart! i would love to run a turbo but i dont plan on racing but i do want a little kick in power . will there be a package offered with everything?.. or at least a full exhaust package?
#136 |
bazinga
Drives: WRB BRZ Limited
so lets see
Stock 174whp Header +4 cross pipe +11 CBE +12 Pulley +12 Combos Header+Cross pipe +5 Cross pipe+CBE +15 Header+Cross pipe+CBE+pulley +26 The gain from the pulley and cross pipe are amazingly high On the other head, I would assume the gain from the header would be higher. individually the header +4whp and the CP +11whp but plus together they only +5whp? Is there anyway to explain this? |
#137 |
Restrictive Muffler and cross pipe. The numbers are what they are. Each run has a list. No ECU tuning.
The AFR's are listed on the bottom black line. All was running very rich. Found nothing lean. A tune can lean out the fuel and and adjust other tables and make more power. The torque will also come up on the header back as well after a tune. |
#138 | |
#139 | |
Drives: Limited WRB AT6 BRZ
I'm curious to see what the total gains are without the AP Pulley, which appears to have a very high gain of +12Whp and +8Wtq by itself. |
#140 | |
Drives: BMW E92 M3
The theory goes like this: 1:1 gear has little or no drive train loss, and is therefore the best (most efficient) gear. Just because it's 1:1 doesn't mean anything, and most people forget the final drive plays a role in the outcome as well. At first I had a very hard time explaining why my BMW on a Dynapack dyno'd the worst in 5th gear -- if it was the most efficient. A Dynapack is a hub-attached dyno, wheels are removed, and operates on the same principle as an engine dyno. Wheel inertia is not involved. The results are only influenced by the motor and drive train loss. So I wondered why my Dynapack results were worse in 5th gear if it was supposedly the most efficient? I spoke to a physics buddy of mine many times. He's a mechanical engineer whose specialty was gears and hydraulics. After a half dozen discussion pondering why my 5th gear results were worse than any other gear, he finally asked if I could get the teeth count of the gears, and he would cruch the numbers and tell me the mechanical efficiency of each gear. The mechanical efficiency of a gear is determined by: 1) How many teeth on the primary gear; 2) How many teeth on the secondary gear; 3) Type of gear cut (helical, spherical, straight, etc.); and 4) Type of coupling (wet, dry, etc.). After he crunched the numbers, we found that my 1:1 gear was the second least efficient gear in the transmission, and 3rd gear was the most efficient; with 4th gear somewhere in between. Viola! The mechanical efficiency calculations perfectly matched my dyno results, and that's when I realized the 1:1 gear ratio theory is just a myth (and a pretty bad one at that). But those results were on a hub-attached Dynapack. Inertial dyno's didn't match these results. On the inertial dyno's, my 4th gear always dyno'd the highest. But I didn't care because inertial dyno's basically guess power anyways based on mass*acceleration. |
| Agency Power Exhaust | vividracing | Engine, Exhaust, Bolt-Ons | 17 | 07-23-2012 03:40 PM |
| Agency Power (headers) | Polo | Engine, Exhaust, Transmission | 1 | 07-21-2012 07:27 PM |
| Enjuku Racing - Agency Power - New Products Released | Enjuku Racing | Engine, Exhaust, Bolt-Ons | 0 | 07-16-2012 05:46 PM |
| FRS on a heartbreaker dyno (Vivid Racing car) | Lonewolf | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 21 | 06-14-2012 07:29 AM |
