Old 08-31-2021, 11:52 AM   #15
J95
J95's Avatar
Originally Posted by thornad View Post
I got a Wayne tune eventually, but I did try the v2 EL AVCS tables and liked them better than v4 (everything else was v4).
Did you notice the improvement with the Wayne tune against the generic tunes you tried?
J95 is offline   Reply With Quote
Old 08-31-2021, 12:07 PM   #16
thornad
Drives: 2016 GT86 N/A
For me driving feels smoother everywhere.
thornad is offline   Reply With Quote
Old 08-31-2021, 02:17 PM   #17
NicFromTheNorth
Drives: Subaru BRZ 2016
Thanks. I purchased a Wayne tune too, but I feel I could get a bit more out of the JDL 4-2-1 in the 3500-4500 rpm range.
NicFromTheNorth is offline   Reply With Quote
Old 10-07-2021, 09:32 AM   #18
J95
J95's Avatar
Hey, did you also tried the stock oft stg 2+ tunes and can you compare? I also feel like there is a bit more to get out of the tune, but I wonder if the wayne tune (I guess Stg2 ACE) would do the job
Old 10-07-2021, 12:14 PM   #19
tomm.brz
Drives: brz 2017 hksv2
email wayno to check your tune and try to squeeze more out of it
Old 10-08-2021, 03:21 PM   #20
NicFromTheNorth
I did, but based on logging street WOT pulls with OFT I did not find a significant difference on volumetric efficiency. I find it difficult to produce repeatable data with street logs and draw definitive conclusions.
edit: I looked back at my logs and what I ran was a hybrid of V4 Stage 2 and Stage 2+, with the exhaust VVT being the average of the two. Overlaying all my data I would say that the Wayne EL maps appear to produce a VE that is a bit higher from 4400 rpm and onwards.
Old 10-10-2021, 08:08 PM   #21
tomm.brz
that s why you should stop wasying time with VVt and just scale well the maf sensor, lean out a bit the afr and put more timing until it knocks
Old 10-12-2021, 11:59 AM   #22
J95
J95's Avatar
Tbh I have no idea what you are talking about Is it worth it to start learning how to tune this and make my own tune using stage 2+ as a baseline? Or is it the same result as with wayne tunes? If so, I would rather just pay him
I´m using JDL EL 4-2-1, uncatted
Old 10-13-2021, 04:31 PM   #23
NicFromTheNorth
@J95, I would suggest spending the 60$ for the Wayne tune and perhaps follow his procedure for adjusting the MAF scaling. Then you could log engine knock and reduce ignition timing if necessary. Otherwise, as tomm.brz suggested, adjusting the variable timing maps can lead you to a path of many ECU reflashes...
Old 10-13-2021, 08:49 PM   #24
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Is there much benefit to a Wayne tune for a car with a basic catted UEL (FT-86 SpeedFactory)?
I keep debating it, but don't really have an understanding of what the positives are. I have no issue with the cost, just want to understand what Id be getting for the money!
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Header/Tune Decision Jakinit Engine, Exhaust, Transmission 50 01-15-2019 10:50 PM
UEL HEADER W/o tune turtlefeeder Engine, Exhaust, Transmission 10 11-29-2016 04:46 AM
Header without a tune eddiev116 Engine, Exhaust, Transmission 73 02-07-2015 07:01 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
FI or Tune and Header? RSH Engine, Exhaust, Transmission 30 10-23-2013 06:09 PM
