#197 | |
Drives: 2022 BRZ
No spacers with the coilovers and pretty sure it was the wheel hitting, RS4 are not that much wide compared to other 200tw. |
#198 |
Drives: 1997 BMW Z3 2.8, 2022 BRZ Premium
#199 | ||
Drives: Crapcan
#200 |
#201 |
Drives: '22 BRZ Limited 6MT
I’m really disappointed that the 18x8.5 et44 w/ 245-35-18s didn’t work. That’s by no means an “aggressive” fitment, and you’re not even using 200TW (read: wide) tires.
Are you sure your rear camber is -2*? If so, this is actually a huge regression from the gen 1 cars. |
#202 |
Drives: 2022 BRZ
#203 |
Honest to god I hardly know how to work this site. Ive never been on a forum before but I left Facebook in the dust and don't have access to any Subaru groups sorry about that, can you quote only the text in a reply?
#204 | |
Drives: Crapcan
The images are posted with an image tag so if you delete the text items wrapped with "[IMG][/IMG]" they will go away.
#205 |
#206 |
Drives: 2022 BRZ Limited
Can someone kindly confirm whether something like RPF1 ET45 17x9s running 245/40 will have any issues with STOCK suspension?
I've read through the thread twice now, it appears all the issues were with lowered setups? I couldn't see any examples of stock suspension. Apologies if im wrong or missed something. This is my first BRZ (loving it btw!) |
#207 | |
Drives: 2022 BRZ
You will need spacers in the front to clear the strut perch which also mean extended studs. |
#208 | |
Drives: 2022 GR86
It doesn't really matter if the car is lowered or not, what matters is the geometry, which is defined by the control arms. If the arms are stock, the car with soft OEM springs can still experience a situation when there's enough weight on one of the rear corners to compress the suspension and bring the tire close to the fender liner. Another factor is how much free travel does the damper have in the compression direction. Some aftermarket suspension can probably be adjusted in such a way that the tire won't rub even if it pokes a lot; whereas with the stock suspension you have what you have. |
#209 | |
So am I correct in saying that if I do have issues with it clearing the fender during compression that I could get an aftermarket LCA and add a little more -camber to make it clear? |
#210 | |
Drives: 2022 GR86
That being said, you can certainly "win" a few millimeters by adding camber. Just don't consider it a solution to all low-offset wheels. It might be just enough for et45, but we're still gathering data to be sure. |
| Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 11:05 PM |
| Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 07:09 PM |
| Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 08:08 PM |
| Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 05:09 PM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 04:34 PM |
