| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#57 |
Drives: 2022 BRZ Limited
Thanks both!
#58 |
Drives: 2023 Toyota GR 86 Cup
2013-2020 Steel knuckles: 12.41lbs each
2022 Aluminum Knuckles: 9.08lbs each 3.33 lbs less each (6.66 lbs net weight less)
2023 GR Cup Car
#59 |
Drives: '23 BRZ Limited
#60 |
Drives: ‘22 BRZ
These might be a good option…
#61 |
Drives: 2022 GR86
#62 |
The front Subaru 4 pots are 40.4 mm, the rear 2 pots are 38.1 mm.
That means same in the front as standard slider calipers with same size rotor. Essentially no change to bias with just the fronts. It's a very mild upgrade, improved feel from the fixed caliper and I think slightly lighter. But the 2 pot rear has smaller pistons with same size rotor. So that increases front bias. I would not use the rear kit on this car or the 1st gen. - Andrew |
#63 |
Track Day Junkie
I think you and I are in the same camp. I really have hopes that this forum is better than many of the Facebook group offerings. I hope experience and wisdom will outweigh the loud know-it-alls I'm hearing here.
I've tracked cars for years on places like Watkins Glen, Lime Rock and NJMP. I'm an ex-SCCA road racer. I'm used to BBK's and a car's performance to match. I'll never accept someone telling me that "the sliders are fine if you just upgrade pads and fluid". Perhaps that might slide by on the rear of the car for many people. Bottom line is there's a reason there are racing brakes. Whether we are play racers or not, if we know how to get the most out of our cars and use the brakes for their 10 tenths potential, then we will want racing brakes. Perhaps we are in the 2-5% that use their cars this way and can turn podium-level lap times. With 245 888R's, and aero, I'll have the potential for being damned hard on my brakes! I don't really want someone telling me what I'll be fine with when I have years of track experience (and they don't even know my car's setup...). These generalizations about one size fits all just doesn't sit well with me. |
#64 | |
Drives: 2015 BRZ Series.Blue
Shhhhhhh your experience means nothing to @ZDan @jvincent @OkieSnuffBox @NoHaveMSG and lots of other professional IMSA driver's saying that stock BRZ brakes are sufficient on the track with pads, fluid and (now) cooling ducts. We're just dummies who don't embrace the power of cheap, single piston brakes on the 2022 BRZ. The lightning lap video drivers obviously didn't know how to drive....a good driver barely uses brakes! Glowing rotors at the Rolex24 are just figments of your imagination |
#65 | |
Drives: Crapcan
#66 | |
Track Day Junkie
Mike, at CSG has already provided visual proof and measurements that the calipers are not up to the task. In his words, "they taco". |
#67 | |
My post was obviously sarcasm directed to the people that I tagged with "@". Honestly, did you even read my post? If you can't detect sarcasm after the Rolex24 tidbit...... |
#68 | |
"Track days" means a lot of different things to different people. - Some are running the Primacies and stock suspension because they just want to go fast. - Some have upgraded to 245-ish tires and some suspension mods and want to go faster. - Some have slicks, full aero, and are chasing lap time records. I'm in the second group. I'm no track wizard but can go fast enough to melt stock pads. I've never had any issues with upgraded pads and fluid. Never. Would the third group need a BBK for performance reasons? Probably. But they are in the very small minority of people. Would people who go to the track a lot benefit from the lifecycle costs of running a BBK? Yes. As in all things, there's no black and white answer so take your own advice and chill bro. |
#69 | |
#70 | |
Drives: Crapcan
![]() Again, as was posted in the other thread about this, T4 cars are required to run stock calipers. They are allowed to run ducts and most do though ducts can cause more heat checking. 21's runoffs was a poor example of "endurance" due to the amount of carnage.
| Performance Pack Brembo Rear Brakes | Chuckable | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 07-20-2023 03:55 PM |
| Performance pack brakes | Jdmuscle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 03-11-2019 06:05 PM |
| FS; Brembo Brakes Performance PCKG 900 miles brz/frs | sokol | Brakes, Suspension, Chassis | 21 | 02-27-2019 02:15 AM |
| RB Performance Brakes BBK for Scion FR-S & Subaru BRZ | RB Performance Brakes | Brakes, Suspension, Chassis | 9 | 06-04-2014 06:52 PM |
