#365 | |
Drives: On order: 2022 ISM BRZ Ltd
https://www.ft86club.com/forums/show...&postcount=349 |
#366 | |
Drives: 2022 brz limited (WR Blue)
#367 | |
#368 | |
Drives: '13 BRZ Limited
My ARC-8 17x9 ET42 wheels with 245 SX2s on a friends 2022 poked on the rear and looked like it would have rubbed. Fronts looked fine. My wheel spec will be very close vs an 8.5" ET35 for fender clearance. |
#369 | |
I think that's a little to far on the back then thanks for the help |
#370 |
Drives: GR86
Guys, it's not the wheel/rim that's rubbing the rear fender, it's the tyres
Go with 235 or narrower if you don't want to cut up anything or run massive camber. For clearance in the rear, as long as the offset is 45 or greater, wheel width (9.5, 9 or 8.5) is irrelevant as long as tyre is under 245. Last edited by 86man; 02-16-2022 at 03:13 AM. |
#371 | |
Codename: Stitch
#372 |
#373 | |
Drives: 2019 C7 GrandSport
Your pics are with factory camber, correct? For a track setup and -2.5 or -3.0 camber should make the top flush with the lip. Do you see any issues with potential rubbing on suspension components in your opinion? |
#374 | |
-3.0 camber would put the wheel 0.445" closer to that shock perch in front, if I have the math right [tan(3°)=x/8.5"]. I measured the clearance there at roughly 0.6" with the factory camber. Even with camber and a drop, I suspect the biggest potential problem area is still that bump inside the rear fender. |
#375 | |
Drives: GR86
#376 | |
Drives: '22 WRB
#377 |
Drives: 2022 BRZ Limited
I am very happy with the 17x9 ET48 in the rear. 245 is fine with stock camber. 255.almost fits. Front requires a spacer, but I decided that was inevitable.
I just put a writeup of a bunch of fitment testing of the 17x9 ET48 6ULs in another thread. |
#378 |
Drives: Too fast
| Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 11:05 PM |
| Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 07:09 PM |
| Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 08:08 PM |
| Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 05:09 PM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 04:34 PM |
